Why fit a pull-cord switch for a shower? | Page 3 | on ElectriciansForums
Discuss Why fit a pull-cord switch for a shower? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I use a Stanley. Works fine for me I suppose. I retract the blade so only a couple of millimeters are showing, no chance of nipping the insulation then. Do you have a better way?
I do, ill try explain, far far easier to show
Hold the cable flat in hand
Using snips, snip upwards either side of the cpc, go even further possibly by cutting halfway into the conductors, then using 2 hands, pull the top layer snipped insulation and the remainder left underneath away from each other, it flies off
Might be hard to understand but if shown you would see, could strip about a metre of grey without damaging innercores in around 5 seconds
I snip it at the top and cut down the centre of the cable with a knife, with the blade angled toward the cpc strands.
It goes through it like a knife through butter, only it's more like a knife through pvc.
Smaller cables i use the common way of pulling the cpc through to split it
I used to mess about for ages with a knife on a 10mm trying not to cut inner cores, until someone shown me this way and then the " why havnt i been doing this for years"
Can't visualise that at all I wanna know how you do it now!
Snip down the centre,bend the live or neutral, whichever, until you can expose enough cpc to grab with the pliers and twist the cpc (making sure you have all the strands)
Hang on to the rest of the cable with a pair of pliers and rip away,pull with a pair of cutters and the cable strips no problem whatsoever
Cut off the mangled end and bobs your uncle,I would be able to strip 100 meters of the stuff in no time whatsoever
I had a shower with no pullcord in a periodic that I later went through on the annual visit from the NIC, I'd flagged it and said it needed one, I think I found a reg that I thought covered it but the NIC inspector basically said I wouldn't have bothered if I were you.
Also was wondering if somebody had set the profile ''the oracle'' up as an alterego to see how many bites he could get?! If not he's really asking for it! :biggrin:
Could someone help I am fitting a shower cable and mk bp ceiling switch . Question is im using 16mm t&e but on the switch the earth is only big enough for 1 wire . So do both earth wires have to go in . And btw my shower is 10.5 kw with a 12 metre cable run so im ok with the cable im using
Reply to Why fit a pull-cord switch for a shower? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I want to fit a Trailing Edge Pull Cord Dimmer Switch in the bathroom with 2 dimmable LED bulbs. LED dimming range is 5-100w for the switch. Light...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
