Why was the RCD test button not working? | Page 2 | on ElectriciansForums
Discuss Why was the RCD test button not working? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening all...
I have just got back from a CU change. All was going very well and I was finishing early which was lovely for a friday evening, and then.......
The RCD on the opposite side to the lights trips when the lights are switched on... arghh. I eventually found the problem, I had screwed through the shower cable when attaching the CU to the piece of wood I was using to hang it on.
Whilst the screw was still through the shower cable (touching N-E) why did this stop the test button from working on the RCD? There was 240V going through the RCD and by using something on the other side of the dual RCD board it would trip, but it would not trip with the test button?
Cheers.
Ha, reminds me of panel wiring where the panel builder puts all the terminal blocks low down at the bottom of the panel. He can see to put his wires in the top side but FFS its near on impossible to "know" where the hole is for the outgoing, end up using the force and trial and error which leads to a bad back and me being grumpy for the rest of the day.
Reply to Why was the RCD test button not working? in the UK Electrical Forum area at ElectriciansForums.net
It was >999 on all, tested cables connected and individually, he ce the reason i came on here to ask for ideas
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
