I've had invaluable advice from this forum in relation to EICR's and clarifying my understanding that just because the consumer unit is "old", it does not need to be replaced. Since then, I had the EICR carried out at my rental property. This went to plan.
I am now scheduling my next EICR on a separate property and this has an even older Consumer Unit but everything works and seems safe e.g. no cracked fittings or exposed cables from my pre-inspection checks.
My question: will this type of Consumer Unit be okay to produce a satisfactory EICR?
Thanks in advance.
I've never worked on consumer units but always wondered how the mains cable is wired into the main switch of the board i.e. is this Live when being wired in?
Also, in terms of working in the board, I assume once the main switch is set to off and you have checked with a 2 pole tester, you are safe to work within this?
Definitely not planning to do this myself!
No.
With experience, yes. You have to be aware of the presence of live parts. Earth wires can be particularly dangerous when installing.
This all RCBO versus split load RCD keeps coming up on here. I wired my place just under forty years ago with a three RCD board and all 12 circuits through one or other of them. All RCDs are in full working order, but, apart from when I've been playing and managed to short a neutral and earth together, the only times I've ever had one trip is when an immersion heater element failed and the dishwasher sprung a water leak.
The inconvenience of RCDs is much overstated IMHO.
