Wiring 2 lighting circuits using one 6 terminal junction box | Page 4 | on ElectriciansForums
Discuss Wiring 2 lighting circuits using one 6 terminal junction box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes you can provided you keep the switch returns to separate terminals. A junction box is not necessarily restricted to a single function such as switching.
That's what im worried about as there is only 2 terminals for SL in the junction box and these have been used up by the first switch
It is the same principle, if you know how connect one switch cable repeat this with the second except the switch return goes to its own terminal. Neutrals and cpcs are commoned to the same terminal.
So the second switch cable can be terminated in one of the loop terminals and one into a neutral terminal ?
The best thing to do if your not sure of a circuit is to draw it out as westward has done. I find it helps to see it set out on paper.
As for your lecturer not being not helping enough get him to go over it until you understand. if you are struggling the rest of your class will probably be the same.
Thanks mate, yeah I know a few probably are struggling TBF, he makes nothing clear, I'm thinking about putting a complaint in to the college
TBH with you all, I suffer with PTSD and get stressed really easily, I had to walk out of the practical session last Thursday because I just couldn't get my head around it, but that's why I enrolled on the course, I am trying so hard for the PTSD to get the better of me anymore, thanks for all your help guys !
Excuse my poor drawing. I have connected the first switch and put the line supply into the second can you see where the switch return now goes.View attachment 45633
Hi Westward i think i have cracked it now, and think i know why there is the need for a connector block, to join switch live to light live on 2nd light, thank you for your diagram, it really helped !
Right, it looks like you are using a Hager J501.
This raises questions like ..... why is your college teaching you to use junction boxes when unnecessary connections should be avoided on new installations, and why is your college teaching you to use equipment/methods not suited for purpose ? If you have to use extra connections jammed in there it's the wrong kit or the wrong wiring method.
Reply to Wiring 2 lighting circuits using one 6 terminal junction box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
Of course, showing my age now!
