Wiring a 5 bedroom house | Page 5 | on ElectriciansForums
Discuss Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
omoeko
London
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
the qualification og ga ga is quite specific. you get your 1st ga when you reach retirement age. the 2nd ga can only be earned by reaching 70 and still working without the aid of a zimmer frame.
My Zimmer frames got an electric start and 2 wheels
But i have avoided the disease of obesity by keeping fit and cycling and walking and never smoked
I will live to an amazing old age, and be miserable as hell
Do you get the third ga when you reach 71 and you are still trying to keep up with things? or is that the C&Gs NVQ in Ga Ga Ga , cos I have lost track, I'll settle with NVQ Ga Ga cs after this afternoon I'm Ga Ga Ga as well as peesed, oh me teas ready got me bib on.
Will do, and you might be impressed. :)
You would be amazed to know the amount of information you have unwittingly provided for an electrician to assess the likely outcome;)
There are those who can
There are those who leave well alone
There are those that can perform well with close guidance and
There are those who think they can
One of the above is the classic disaster waiting to happen,mostly they are not even aware of their shortcomings
OP (late to the party), I don't understand why you have an electrician to carry out this work. Then you come to this forum to Q&A your list of materials, surely your 'electrician' would provide you with a list?
Is it me, or have we had a series of threads of a similar nature. Co-incidence or conspiracy theory :confused:
pete just for the record, you were awarded a 3 star ga ga back in 1937. :p
Reply to Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
