Wiring oven with seperate hob | Page 4 | on ElectriciansForums
Discuss Wiring oven with seperate hob in the UK Electrical Forum area at ElectriciansForums.net
C
Cj24
Hi just a quick one Iv wired ovens ups few times but never wired a hob and oven seperate, so just want to check obv size depending is it for example 6mm from isolator to hob? Then take your oven off the ring in kitchen or poss pull on it's own 4mm radial on 20amp
Reply to Wiring oven with seperate hob in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
