L
lofty84
Hi guys if anyone could help me out here I would really appreciate it. I've got to wired up a immersion heater. There is a switched fused spur mounted on the outside of the cupboard housing said immersion heater from this is a piece of flexed which need to be wired in. On top of the immersion heater is somewhere for the cables to go on the left is a heatrae terminal with a minus sin above it and on the right is a rdg terminal with a plus sign above it i take it live goes to the right and neutral to the left and the earth to the bi screw which says warning this alliance must be earthed. If so I will need some sort of earth crip and then a nut to tighten it down and make sites there a good solid connection. Any help greatly appreciated as there waiting on me to do It
