wood bits ??? | Page 2 | on ElectriciansForums
Discuss wood bits ??? in the Electrical Tools and Products area at ElectriciansForums.net
ive used lots (and lots)of fast 4 and irwin bits and some cheap copys.
you can re touch them with a file when worn..but nails are a problem.
i love em an 18v battery drill will do a 25 mm hole in a joist as a rule but a 240v angle drill and you can drill through anything made of wood no worrys.
this said id like to see what angles these bits should be sharpened to...i just guess a bit...works for a while.
i hate to throw a new bit just coz of cliping a nail when 98% of it is good.
better still are joists with knockouts or steel rail between....super joists ..love it..
ta
vito
Reply to wood bits ??? in the Electrical Tools and Products area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
You’d have to change the size but you could just fit an LED panel behind the Perspex or whatever it is you’re using for the opaque top. Sizes of...
