work in progrees in Micro Brewery. | Page 3 | on ElectriciansForums
Discuss work in progrees in Micro Brewery. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
s title. soon be up and brewing.
[ElectriciansForums.net] work in progrees in Micro Brewery.
It takes a lot of balls to put pictures of your work up for public scrutiny. Constructive critique is one thing none of us is whiter than white on 100% of all jobs not than we would like to be. I think you lot are being a bit hard on Tel if he is using the correct gland out of the packet the shroud may need a bit of heat to make it a bit pliable, do you really think he is going to leave the rubbish on the floor and the cover off the other isolator.
It's a shame Tel let the customer tell him in part how to job a bit of tray or similar to take the cable on over the conduits.
The cost of a job or the budget available should not detract from the requirement to comply with relevant Regulations.
Tel's a Scouser, I'm a Manc, taking the proverbial out of each other is what we do! :D
@ westie. i can see your point. the original plan was to cleat all 3 cables, but then it would look like the london underground track. who is to say that a cleat can't support 3 cables? the cables are adequately supported and reasonably tidy. if there was a fire, OK, they's sag, but so would all the existing singles in pvc tube sag. as said before, my original plan was to run on 3" tray, but customer declined the additional £300 cost.
Reply to work in progrees in Micro Brewery. in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
Bugger that. They end up in whatever position they want :D
    • Informative
