Currently reading:
Wot! no earth? Hmmm! had to add this bit to pass the title rules?
Discuss Wot! no earth? Hmmm! had to add this bit to pass the title rules? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I decided to change the flex on a small 2kw heater as it came with a fairly rigid wiring to the plug. I was surprised to find there wasn't an earth being used. Also the heater it replaced had a cut-out switch on the base, this one hasn't. Explanation please. Thank you.
Hi all,
Different type of heater has it got something like this on the heater?
Google Image Result for http://www.gcsescience.com/double-insulation-symbol.gif - https://www.google.co.uk/imgres?imgurl=http://www.gcsescience.com/double-insulation-symbol.gif&imgrefurl=http://www.gcsescience.com/pe38.htm&h=123&w=175&tbnid=7EL7kU_o2AaBPM:&tbnh=123&tbnw=175&usg=__DdI9rZKygJah7cTJ-M2JyXWKqgI%3D&vet=10ahUKEwiuzrrVqfHZAhXMAMAKHSgRBXkQ9QEILTAA..i&docid=Y4iZ3W7418FCbM&client=firefox-b&sa=X&ved=0ahUKEwiuzrrVqfHZAhXMAMAKHSgRBXkQ9QEILTAA
Hi all,
Was it purchased from a reputable source, and has a CE mark (& wot Pete said) and not the Chinese one.
Most modern domestic heaters are class II equipment that does not require an earth.
The heater is constructed so that there would have to be a double fault for the external parts to become live.
The heater ought to still have a cutout however the cutout is probably inaccessible inside the equipment, if you can see into the heater (when off) and see the element the cut out should be a little way below the element but it may not be very obvious.
Thanks Pete & Richard, it does have the "square within a square" symbol on the base. Also I noticed the thermal cut-out when I had the cover off to rewire, & Scouse is correct, I was referring to the safety cut-out that would usually be on the base. Still find that omission as rather odd. Purchased from B&Q & it has the CE mark.
Quite a nice compact heater. If frost/snow is forecast, I suspend it from a hook that I've fitted in the overhead storage shelf in the car to de-ice the screen & is switched on ½hr prior to wanting to go out. Works a treat.
The symbol indicates it's a double insulated appliance.
Reply to Wot! no earth? Hmmm! had to add this bit to pass the title rules? in the UK Electrical Forum area at ElectriciansForums.net
