Zs test at last lighting point reading "trip:" | Page 3 | on ElectriciansForums
Discuss Zs test at last lighting point reading "trip:" in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Baazab, make sure you use the supplied little plastic shrouds that go over your test leads when doing any live testing very important for preventing interesting flashes and bangs and would probs mean a fail in a practical exam.
Your tester will read trip if you momentarilly lose contact with the earth connection , which on the meggar1553 is easily done if you testing at a lighting pendent because those leads are about 4 inches to short if you don't use steps and if your doing a no trip rcd test on a lighting circuit it almost becomes a two man job !
i got a set of those as well off ebay a few weeks ago - really fancied the yellow/orange socket and see ones but they were £16 dearer. bound to lose those dark lightmate ones in the bottom of my bag :eek:
I've got the 1553 it seduced me with the two lead options and Blue Tooth, doubt I will ever use the BT though it seems a ball ache, it has taken me ages to get used to the Meggar the dials aren't the best or clearest, I had Kewteck singles before but the RCD tester though claiming to be non- trip doesn't now work with modern RCD's as I think the new RCD's are more dc sensitive and I think the old Kewteck used to send a dc pulse down to annoy the RCD long enough to do the test, but not sure on that
Mft 1553 zs problem
Hi. I have the same problem with my mft 1553 on site. When doing a 3 lead test on the no trip finction it just appears "ert" after 5 seconds. I tried mi tester on various properties and the same thing happens. The probes are ok and connected fine and the circuits come out good on the dead testing. I'm shure there is a promlem with the tester. Please advise.
check the manual for error codes - it is available on line if you have not got the original. There are links to it on here somewhere :)
Reply to Zs test at last lighting point reading "trip:" in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Any electronics in circuit that might be skewing the readings? Smokies. Or smart switches? Might have been covered already, but what about...
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
