Currently reading:
addition to ring
Discuss addition to ring in the UK Electrical Forum area at ElectriciansForums.net
Sounds like a N to E fault somewhere - and not necessarily on this socket circuit.
Some additional information might be useful - what did "all tests" consist of, and what actually were the test results that were "good". And a description of the board configuration would be helpful.
As above more info required You could of trapped a neutral at one of the new socket or when you pulled the new cable in you could of burnt the cable against another one or there may be too many appliance now with high earth leakage on the circuit, did you get good IR results
end to end figure of eight IR >999
L 0.74 L cpc 51.2
N 0.74 N cpc 72.3
CPC 1.04
The way you have wrote the reading do not read correctly
I think you mean Ring reading
Live to live 0.74
Neutral to Neurtal 0.74
CPC to CPC 1.04
and IR test
IR >999 Live to live L cpc 51.2 and N cpc 72.3
Does the RCD test OK with nothing connected
Is there any load on the ring circuit ,
How have you installed the new cable ( if they are with other cables the could be burnt together when pulling them in) May be worth doing IR between the ring and other circuit if this is the case
Have you checked you have noted snaged a neutral when pushing sockets back
I would hazard a guess that as the RCD holds up when the N for the RFC is disconnected, and it was OK before, it's something you have caused, check from the points of addition.
Reply to addition to ring in the UK Electrical Forum area at ElectriciansForums.net
