So why not all in one suitable/sized db?
Boydy
very narrow space and to many circuits..i cant fit single db ..its more easy to do on this way..
Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
Boydy
They returned next day removed the rcd fitted rcbo's throughout lol and didn't charge for it.... lesson learnt i hope, although domestic hasn't got the same enforcement of these regulations as the consequences are not as dire.
Boydy
I can't understand why any commercial premises, ....and especially food and/or beverage outlets, such as Pub's, cafe's, restaurants and the like, would have a dual 17th edition CU/DB installed, it's just asking for trouble...
People going off about ''high integrity boards'', ...well you can't get much more high integrity than a RCBO CU/DB can you!! A damned sight easier to fault find on as well, if and when the occasion arises...
Absolutely. But that's where the word 'design' comes into play....it's not just simply formulaic that you do x,y,z. OK, the bulk of my work is domestic because that's whats defined geographically but I never just simply 'bung in a 12 way split' unless that is genuinely the best answer.
You use eyes, brain, experience and technical knowledge to produce the most applicable solution.
It would be a bit like a dressmaker only having one size mannequin, one type of material and the same pattern. They couldn't really lay claim to the title 'designer', could they?
View attachment 22003For a cannibas farm. They wired the ring main directly to the live supply coming from the common stairwell bypassing the meter. They must have wired it live as well, as there was no access to the incoming fuse. Into a connector block with the 100A meter tails.
Ha ha. I'm sure I would be more if I did this sort of work - reducing electricity bills by 60%. Just don't tell Scottish Power.This is posted in show us your installs? I think you need to work on your design and I think your finishing touches need a little tweaking but apart from that you've made a nice job.
Yes in ducting all selv. What's the problem with that?
Just to add to that, the manufacturer of this cable states it should not be connected to mains voltage.
This is not entirely true ... the suppliers i know specify it shouldn't be used as a power supply cable as in tails or similar but it can be used to carry voltages up to its rating which means supplying motors like I use it for from inverters (400v 3ph) with screening to comply with relevant EU regulations...
Its misuse is the over promotion of wholesalers selling it as a rough service cable which it is not as it ends up been used for extensions etc which is totally unsuitable for ... ive had 3 accounts of people getting shocks of unearthed or corroded braiding because of a tack, nail metal bur etc piercing the live only making the braiding live!
I just seen a factory with all its machine supplies wired in sy with taped off screening and to say its been wired by an Electrician does make me wonder how this stuff has found its way to been utilised so many times for the wrong purposes...
Again it can be used with LV but you need to know its limitations and ensure its not used as a alternative to an extension or frequently flexing cable.
The 230v is for a commando socket below. Sy was chosen because the control side requires a screened cable with multi cores that is flexible enough to connect to the lights. sy seemed the best choice. All cables are glanded correctly with the braiding and no just using stuffing glands. What makes sy cable unsuitable for outdoor use.?
Is that standard to use unistrut as a cable containment system?? ...photo's #3 + #4
Are they unprotected/uncontained singles going in to that emg beacon?? ...photo #4
If the SY is not 100% shielded from the sun then you should look towards another cable with UV protection attributes ..the outer sheath is so designed on purpose mainly for machine use and similar control needs as it is see through and any degradation of the shielding/braid can be easily inspected.
Because the sheath is clear it lacks a lot of attributes found in most cable sheaths and even the ones it gives like moderate acid and oil resistance only apply at room temp' and can't be guaranteed when subject it to temp extremes... How its use has been catapulted into this fits all solution when it is clearly unsuitable for most purposes the average Joe spark utilises it for...
Pop onto RS Components web site and you'll find many better suited to your needs that don't have the limitations SY does although RS's downfall is it doesn't cut to length so Scatts maybe a better option .. the problem is most general wholesalers don't stock any other shielded cables so i assume this is a reason for its explosion into the scene of misuse as SY was promoted as a suits all cable with added mechanical protection ...a lot of uses took this as a open door for blindly misusing it.
The problem with screened cable is the expense of suitable glands but as SY has flooded the market it has seen a budget gland enter the market that is affordable.... if you venture for more suitable alternative expect the reality check of expensive glands to enter the arena again.
Spent £50 on a panel receptical and Free-plug with extended screen clamp other day - extortionate just to connect a cable to a panel :O/
The beacon comes pre-wired but it goes through a bushed entry,thanks.
haha i think u need to calm down eng, i only put these pics up to draw u in.
ps get help.[/QUOTE]
Behave yourself!
heres a couple of my last jobs.first one is a new switch room upgrade which im still on with. then a control panel controlling the temperature on two mixing vessels using PT100 probes
View attachment 22343View attachment 22344View attachment 22345View attachment 22346
Surely if it's underground in ducting then sunlight isn't a problem. Daz
ps get help.
Do you have issues to deal with? I'll pray for you friend.Yeah right, of course you did!! I believe that, about as much as i do your 30 years experience!! Or was that in Doggy years!! ...lol!!
900m long x 500m wide and 30m at its highest with a 5 story Mezz, my feet are ruined lol
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
