- Reaction score
- 2,810
Few more pics
Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
darwood said:What about the ones marked up 230v ???
Can i ask why you chose SY ... its often misused and incorrectly installed and over the last 5yrs ive ripped out so much of this crap.. its design as a control cable the braid is a screening and is not mechanical protection, the outer clear sheath is unsuitable for outdoor use and whenever its is utilised as a power cable for LV the braiding should be earthed but a must is that it isn't used for earth.... not saying you have done any of this but interested to why this cable was chosen as i cant see any benefits with using it?
Seen on an Inspection...
Looks like it's in a commercial kitchen so what do u expect?
Always good to see clear and specific labelling.Seen on an Inspection...
Fire alarm i installed.
heres a couple of my last jobs.first one is a new switch room upgrade which im still on with. then a control panel controlling the temperature on two mixing vessels using PT100 probes
No its not standard. They're jumped off tray to strut, and it would have looked better with a bit more tray but not needed.
Of more interest, keep us informed of what ELECSA do. Or don’t do as is more than likely.
Had to put a new sub board into a restaurant kitchen and drop 11 new feeds into the kitchen for equipment. We only had 2 nights to do it and there was only really room for 2 of us.
So far so good for the cable dressing, not sure you will have enough room behind the busbar for those folded cpcs, remember to take the cable ties off once complete and tested.Hey,
Just started one today, would like feedback, see where i could improve.
"Don't be too harsh, I'm only an apprentice and this is my first time doing a new board complete "
Finishing it off tomorrow hopefully - when the breakers show up to site ....
Hey,
"Don't be too harsh, im only an apprentice and this is my first time doing a new board complete "
Hi daviesjoe .... my comments are thus :-
Remember grouping factors may have an influence if your going to bunch tiewrap as you have.
Once you have fitted the internals and OL devices your cable terminations will require identification due to your methods here, which N/E belong to which L are not easily visual identifiable as the internal busbar section with cover the entry point of most of the cables you can't rely on the actual no of the terminal you connect to you should in theory be able to drop all cables out and be able to easily identify which is which.
Welcome to the forum you are indeed a brave lad to show us your install on your first visit asking for our advice --good on yer!
Yeah the boards up the wrong way mate.... just kidding good work mate and very neat indeed.
Did it take you 3 weeks to do though??? well done
Are you staying this because there appears to be no identification on the neutral and earth bars or are you saying all terminations should have?
Whilst i agree with your thinking a minute in that board with a screwdriver and long nose pliers and i would be able to identify the conductors for one cable. Id say if the terminals are marked id say the OP has complied with 514.1.2, by its arrangement with corresponding terminals which are numbered. 514.1.2 doesnt say anything about must be able to identify all conductors of a cable just by looking.
As i say i agree with your thinking and workmanship standards i dont think 7671 is asking for cabling in the switchgear in this case to be marked.
We are talking about 7671 minimum compliance here if a clerk of works wants it i think that is more than 7671 is asking for and therefore would be in a spec somewhere. If we were talking about very large boards here I think you could have some argument but in a small domestic board i dont believe it is required. Yes the regs should be applied to all install but that doesnt mean blanket regs, if this was the intention 514.1.2 would be far more explicit in its wording. 'reasonably practicable' is used in the reg, as i said with the fuseboard in question one minute and i will be able to identify all conductors from a cable, sounds reasonable to me. On a huge three phase board which may have had the cabling not run sensibly like behind centeral bussbars for neatness this may be far far longer and may involve dismantling, we are now possibly into the realms of beyond 'reasonably practicable' but even that is up for debate as with terminals numbered the conductors are still 'arranged' so may well still satisfy the reg.
For me cable markers are not required for the fuseboard pictured. 514.1.2 is far too wooley to apply in this instance i think.
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
