Search the forum,
Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
Neat job :biggrin5:
Called out to a job because the fuseboard they installed themselves started buzzing and glowing blue when the lights were off!!!
ImageUploadedByTapatalk1348844044.530750.jpgImageUploadedByTapatalk1348844062.281847.jpg
On inspection the neutral from the Rcd main switch wasn't done up in the bar and had burnt through. So no contact to the circuit neutrals.
Not bad for a 3 month old install!!
LOL
Three month old install but with old colours? That Protek rubbish would have probably set light to itself eventually anyway, lol.
View attachment 14858View attachment 14859
LOL
Been to a job today, Romanian sparks maintenance free JB. The whole extension and existing houses lighting not a single screwed terminal used other than at the fittings and switches and no earth cont anywhere lol.
Quality:)
Care esta problema cu ea. Am testat-o cu o lampa de mesa si fuctioneaza perfect in bara, astfel sa si reglementarile......
I know I've seen plenty myself just never remember to get any pics, this ones up there though:clap:
Good point, I either don't remember, am too scared to put anything conductive near it, or am too frustrated at trying to explain to the customer why it's a bad thing to get my camera/phone out.
Changed a cu today, On testing of the rings up and down.. end to end ground floor. R1 0.53 Rn 0.53 R2 0.79....first floor R1 0.54 Rn 0.53 R2 0.83..... Both rings were fine on the old rewireable DB. The ground floor ring is fine on the RCD, but the first floor trips, after testing it appears to be a fault between neutral and earth, I tried with just the live and neutral wired. no trip.....plugged in a tester and all three lights come on, I was expecting two lights suggesting no earth. the house has had four extensions over the years and it's a right balls up with sockets on the ground floor in the SNUG on the first floor ring. In one of the bedrooms upstairs in an extension there are two double sockets and one of these is a spur from the ground floor ring.......
Over the weekend I'm going to have to try and find this fault, and try and find where the earth is coming from.....Does anyone have any suggestions. ?????
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
