Search the forum,
Discuss Velux remote (battery controlled) issues in the UK Electrical Forum area at ElectriciansForums.net
llyamah
Hi all. The short question... Can electric velux windows send a signal to a AA battery-controlled control pad that causes the control pad to quickly deplete the batteries?
The details...
I have three electric velux windows in my kitchen and two in my bathroom. All recently installed by the same guy. All use KLR 200 control pads operating 3 AA batteries.
No issues with the bathroom but the kitchen control pads don't hold a charge. Within a month the batteries are completely dead.
Each unit is placed on a wall next to a nest thermostat.
I've tried multiple control pads and same issue over and over again. It is possible the control pads are from a bad batch and all suffer the same issue, so I have requested two new ones from velux. I've just set these up and will wait a month and see how they go but in the meantime I thought I would ask the question here (there's no battery % indicator on the unit).
What could the issue be?
Could the windows be feeding a constant signal to the control pad keeping it 'awake' (the screen isn't on).
Could electrical current to the nest thermostat be interfering with the batteries?
The units do say 500ma max on them but surely that doesn't mean that I can't use batteries with a higher capacity (some of the batteries I have tried are 2000mah rechargeables, but I think I first tried the batteries the unit came with).
Hi,i have read the KLR200 operating handbook....what a trawl...i know why i have curtains...
Just a thought,is the control pad,designed to operate with rechargeable batteries?
I know there are only 3 x AA,but the voltage will be different.
One of the control pads,shows a battery level indicator,so is this not working?
Most remote controls (TV etc) are better with standard alkaline batteries because of the self drain of rechargeable types. As PEG says, make sure they are designed to be used with these.
Thanks for the replies both.
The battery level indicator only works to show there is a 'low battery', not to show a day by day level (unless I am missing something?!).
I am not sure if the control panels are meant to work with rechargeable batteries...
The label says "5 V d.c. max. 500 mA".
The rechargeable batteries are 2000 mAh, 1.2v... Are they ok for use?
Even if the rechargeables are not okay, I swear I had this problem using the stock batteries provided by velux. I could be wrong though - maybe I was using rechargeable ones from the srart.
Any further thoughts wpuld be appreciated.
Wired supply for a friend for Velux with similar controller, he used batteries that came supplied, i.e. not rechargeable. Controller in my older Velux, used normal AA batteries.
I’d give that a try, as suggested.
Can the remotes be paired with the other Velux?
I’m thinking swap the remotes from room to room and see if it’s a remote control problem or a location problem.
Try alkalines and I reckon you will be OK. Not the ones that are 30 for a quid at the pound shop though!
@llyamah
Just wondering if you ever got an answer for this, I'm having the same problem with one of my velux windows. Using standard AA batteries D'cell/E'giser.
He's not been on here since last January.
Maybe someone else has had a similar problem though.
Reply to Velux remote (battery controlled) issues in the UK Electrical Forum area at ElectriciansForums.net
I have 2 Mira dual valve vision showers. The remote control.for the Vision model has been discontinued, so I bought a Mira Platinum dual...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
It's a simple question. Velux 3LR A02 WW wont turn on So I have two Velux 3LR A02 WW to sort out - I've tried with the USB Ports and the battery...
