Guest viewing limit reached
Darkwood
Mine was an old cooker hood I took down. Supply had been taken diagonally from a socket above worktop.
Whoever put the old hood up managed to drill through the cpc of a t&e... the rawl plug acted as an isolator between the L and N which hadn’t been cut.
Hood worked, just never been earthed.
classic. i had one the other week, rawlplug and screw through L courtesy of kevin. screw was live, so he stuck some tape over the screw head and told customer it;s safe now. FFS.
It’s amazing the amount of times someone manages to put a screw / nail through a buried cable breaking the cpc and only just scraping the live and neutral Cores...
Failing to trip the mcb & leaving the cable live but without an earth beyond the hole.
perhaps buried cables should be of screened type so the cpc is fully around the inner cores..
I thought I’d uploaded this pic before.....
From this....
Source URL: Someone was a lucky so and so - https://www.electriciansforums.net/threads/someone-was-a-lucky-so-and-so.174087/
True. The above one is the same. But, in this case, with such a small pin shorting L and N....and the earth having no insulation, it tends to take the majority of the blast.
It was a right job double heat shrinking with the lack of length available.
Sand and cement wall :mad:
8K
Darkwood,
vjsmarwick,
