True but that is not the point.But aint MF
is that mixed grill a mixture of lever wagos and push-in wagos. ? bearing in mind that you need the lever type for the (flexible) onion rings.Quite different indeed. In one, the cables are clamped by screw pressure against a piece of brass of negligible resistance, whereas in the other, they are clamped by screw pressure against a piece of brass of negligible resistance.
Having finished work now, I'm off home. Kat is still away visiting her family so I am going to have a mixed grill. I'll fry a couple of Wagos in case I need to spur off the onion rings, although there isn't mushroom in the back box.
TTFN
?Quite different indeed. In one, the cables are clamped by screw pressure against a piece of brass of negligible resistance, whereas in the other, they are clamped by screw pressure against a piece of brass of negligible resistance.
TTFN
Your right of course, I think I lost the plot frustrated by the other issue. Current will flow according to the rules for parallel conductors and of course at the point of load the resistance of one path will be different to the other.I don't think this is quite what you meant to say. Either that, or you will have to haggle with Mr Ohm and get him to change his ideas about proportionality between V and I in metallic conductors.
Yes it is. But on another note, much nicer than raft of ugly FCUs.Satin Chrome Customised Kitchen Grid Switch Panel with White Switches - 4 Gang: Amazon.co.uk: DIY & Tools
Free delivery and returns on all eligible orders. Shop Satin Chrome Customised Kitchen Grid Switch Panel with White Switches - 4 Gang.www.amazon.co.uk
Isn't this going to end up as multiple spurs from the same point on a ring when fitted?
Yep. On my ring, which has 16 sockets off it - 12 double, four single. The kitchen is not far from the CU. When the toaster is on, 75% of its load is through one leg of the ring. So, when the full 32A is being drawn, if all the draw is in the kitchen bunched up, 24 amps will be through one leg. This is within the 27 amps of the 2.5 cable.This one shows dishwasher, washing machine and tumble drier. Hardly distributing the heavy loads around the ring! About the full 32A from this one point from just those three.
i wouldn'tput it on anything other than a skip. the number of fail ed switches i've encountered on those appliance grids is phenomenal. seen loads bridged due to this.Not if it's fed by a 4.0mm² radial. I wouldn't put that assembly on a general-purpose ring out of choice.
Neither would I, but plenty would. To be more exact, I wouldn't use those panels at all by choice.Not if it's fed by a 4.0mm² radial. I wouldn't put that assembly on a general-purpose ring out of choice.
They look like grid switches.i wouldn'tput it on anything other than a skip. the number of fail ed switches i've encountered on those appliance grids is phenomenal. seen loads bridged due to this.
they are grid switches. generally specced by costomers who don't want FCUs or D/P switches along the worktops. then they moan when the dishwasher/freezer/washing machine wuuna work coz the switch is broke.They look like grid switches.
You can make up grid switches cheaper. My experience with grid switches, is only buy the branded quality ranges. Frustrating and time consuming when fitting with so many wires in tight locations. Some carrying high loads as well, which is off putting. They are convenient and neat looking for the users though.they are grid switches. generally specced by costomers who don't want FCUs or D/P switches along the worktops. then they moan when the dishwasher/freezer/washing machine wuuna work coz the switch is broke.
