Dude, we know how Wagos are constructed. You're clearly set on doing whatever job this is your own way, we're just telling you it doesn't comply with the regs as written, whatever sophistry you come up with.The bus bar clearly seen on a three connection Wago. It is 5mm thick.
Will direct me please to this reg.we're just telling you it doesn't comply with the regs as written,
Will direct me please to this reg. Dude.
As I have read, it most certainly applies. This is one of the points I am clearly making in this thread. Taking spurs off a bus bar that the ring's current runs though is what they promote.
For that one, I'll have to defer to my UK colleagues. Funny thing is, under Australian rules you'd be fine, we don't use ring final circuits so all final sub circuits are protected by an MCB/RCBO suited to the cable. Hence we can apply the full load at any point on the circuit without worries.Will direct me please to this reg.
As I have read, it most certainly applies. This onen of the points I am clearly making in this thread.
You can only advertise if you are a sponsor.Can I contact admin??
It is about advertisement on your website.
Thank.
I have no misunderstanding. You are interpreting your idea of what a point is, which is not mine. I formed mine by looking at the bus bars in the Wagos and how they apply to rings and spurs off rings.I have a feeling that the core of your misunderstanding is the meaning of 'point'. In electrical practice, this doesn't mean one microscopic locale in space, but one 'place' in the circuit. Hence a power 'point', lighting 'point' and a junction box is a 'point'. All the constituent parts of your wago connector are all one point.
What is clear is that Wagos (and in-sure) have a bus bar inside with a point(s) off the bus bar with a cable connection on that. Nothing says the points have to be feet apart. One poster brought up a heavy appliance terminal switching unit, where the heavy appliances of a ring are about 1/2" apart on a ring.
British rings have no problem in plugging in appliances anywhere once designed properly. As long as one leg does not exceed its cable current rating all is fine regarding balance.
Regarding radials in other countries, I have always been uncomfortable with them not having fuses in the plugs, as is standard in the UK. So, a table light with low current flex is plugged into a socket, with the only protection being a 16A or 20A mcb at the consumer unit. That table lamp's flex will cook if they is a serous fault. Dangerous. My kitchen toaster is 800W, It have a 6A fuse in the plug. I always put 1 A fuses in table lamps. The flex and appliance is then protected properly.
I know people who have bought houses in Spain and France. They first thing they did was to fit UK 3-pin sockets and plugs on the radials inserting the correct plug fuse for the appliances. Were the appliance was over 13A they left the existing socket and plug - these are fixed appliances like dryers. I am not aware of continental plugs having fuses in them - unless someone knows of one on the market.
On the continent, I have never seen a table lamp with a 8w LED bulb, with protected by a fuse in it or in the plug.I don't think they need to. Aren't EU appliances designed to be safe to use on the European 16A radial circuits?
I have never seen them.Never had a problem in Spain. Some sockets are fused, with little glass fuses, and these are for table lamps.
