View the thread, titled "Have the rules for ring mains changed over the years?" which is posted in Electrical Engineering Chat on Electricians Forums.
In what way are the electrics nicer?
And what makes their CUs so much better?
Plastic quarter turn screws that become brittle and break, use of screwdriver reduced by 1/3, DP breakers that take up twice as much space and not much else, other than more money to be made if longer jobs are deemed better than getting finished and moving on to the next.
Apparently.
More room in the CU to work, wago'd earth bar, double pole breakers, no dreadful flat profile cable, more appliances on separate circuits giving better selectivity, main switch provided on incoming head as standard, pre-sleeved earth wires, pre-wired conduit, better selection of fittings (especially for lights), better light switch rocker size, no ring final's, better looking plugs, variable supply (bringing it down brings standing charge down), colour coded cable so you can see on sight what size it is....
Just obviously better than the horror show here in the UK.
Wait until you see how they slate roofs. Although i'm sure someone will try to say pinning with nails like we do is best.
Yeah but what makes them nicer lol.
As long as you choose the right CU then there's not much issue with ours.
wago'd earth bar,
Interesting, that sounds like a good idea, do you have an example of this?
Yes because they require them for safety on their single phase circuits, our single phase supplies/circuits are safe with DP MCB's. DP MCB's and DBs are available in the UK when they are required.
Whats wrong with flat profile cable?
I'm not sure how this affects selectivity?
Interesting, I'm aware of the need for an RCD/RCBO at the supply head due to their common earthing systems and restricted current supplies.
Supply isolators are becoming common here for small supplies and I agree that it's is a good thing that we should have been doing years ago.
Why does that matter?
pre-wired conduit
Whats that look like? Doesn't that defeat the object of having conduit in the first place?
Surely a pre-wired conduit is just a cable?
OK, but that's personal choice and I can't say I've ever had an issue with the available selection of light fittings in this country.
Is there a particular type of light fitting you feel is missing from this country?
If you want bigger switch rockers you can get them in this country.
This is really starting to sound like you are clutching at straws.
, no ring final's,
Why is that better? It's just a different way of doing things.
Really? That's such a subjective thing and really not important is it?
Why does the look of the plug matter?
Does it, or rather, would it?
I doubt standing charges would go down if you introduced that as the cost of altering so many supllies would be phenomenal.
I hadn't realised that idea had spread to mainland Europe, I thought it was only in the USA that domestic electricians needed colour coded cables to be able to identify their size!
Do you have any examples? Ive not studied electrical installations in mainland Europe but from what I have seen I thought most of their cable was plain white.
I really don't see how you can describe UK electrical installations as a horror show.
We have spacious boards, although not historically common in domestic installations as we don't generally require so much room for protective devices.
Very common here and usually require half as much real estate in domestic boards.
Of no relevance to the subject. Sheath only needs to enter the board and it is generally the case that only individual conductors are brought forward.
No reason that wouldn't be the case in the UK. The difference being we have more choice where circuit design is concerned.
DNO equipment is of no relevance when comparing the niceties of French CUs.
We can have those too. Again a matter of us having more choices available in circuit design.
pre-wired conduit
Not sure how that's a benefit, unless cable type and size is limited. Seems like a nightmare for wholesalers, unless this convenience is limited to specific circumstances. Imagine how much more storage would be required if all cable arrived in its own containment. Is only one type of conduit available or does all of the above have to be stocked in multiple conduit sizes?
Can you elaborate or is this a purely subjective opinion.
Perhaps you haven't seen the choices available in the UK?
no ring final's
Better or nicer how?
Very important. Who cares about safety or convenience?
This makes for prettier CUs?
Seems reasonable, but how do you determine type of colour indicates size.
Experience tells most people what size of cable they're dealing with. Perhaps your opinion may change as experience is gained.
That settles it.
Can you do plumbing again? It's been a while.
I'm astounded that you've deviated so far from the thread subject. Didn't you admonish someone for the same offence yesterday?
Reply to the thread, titled "Have the rules for ring mains changed over the years?" which is posted in Electrical Engineering Chat on Electricians Forums.
