R
rewireIT
Dunno if you can choose to but i've seen it done without.Very cool. Do they have to pin the verge slates, or will the clips hold them in place too?
Seems reasonable, but how do you determine type of colour indicates size.
This is done in the USA, their Romex cable which is the equivalent of our T&E has different coloured sheaths to denote the common sizes used. I believe there is white, red, yellow and black.
As an apprentice you probably don't know that you're not always up close with cable, enough to determine size.Experience tells most people what size of cable they're dealing with. Perhaps your opinion may change as experience is gained.
Are you now disputing your own point?As an apprentice you probably don't know that you're not always up close with cable, enough to determine size.
The actual electricians on here probably know that.
Nor would I. The word "replacement" was rather key! I must be sinking to new depths of literary regression as it's taken me three posts to convey the idea that you have a small space, and only a small new cu will fit in it, and small new CU's can't have as many circuits.I wouldn't be adding more circuits to a re wireable Cu.
Well onions grow better after you've used a horse and cart.There are benefits to using a Ring final, there are also benefits using a horse and cart compared to a van.
I'm getting a bit sick of multiple attempts by multiple people to steer this back to a reasonable debate and lighten the mood being undermined by you resorting to being offensive. Have an onion and chill out.As an apprentice you probably don't know that you're not always up close with cable, enough to determine size.
How often does this situation occur? And of those times how often does it occur with a sheathed cable where you can see the sheath?As an apprentice you probably don't know that you're not always up close with cable, enough to determine size.
Measure distance across…. Half it, square it, multiply by pi….I actually had a situation this afternoon where I was trying to identify the size of an existing cable and I wasn't sure about it.
It was either 185mm or 240mm singles, but I don't work with sizes often (if I do I prefer tri-rate for obvious reasons) and also being quite old the insulation can be a bit thicker and confuse things.
I've solved it by adding both sizes of lug to the parts order so that I'm covered either way.
Maybe if someone had painted the trunking according to a universal colour code it would have been better?
I'm quite prepared to stand corrected, but don't believe French cable of that size would have been any easier to identify.I actually had a situation this afternoon where I was trying to identify the size of an existing cable and I wasn't sure about it.
Shaped conductors are known as sectoral.I'm quite prepared to stand corrected, but don't believe French cable of that size would have been any easier to identify.
Those sizes of singles confuse me as I'm more familiar with them as shaped conductors in multi core cable.
Searched my memory for that term and failed. Figured 'shaped' would get the point acrossShaped conductors are known as sectoral.
