EICR and unnecessary work?
@ P&S,
I too am not disagreeing with the merits of RCD's, I believe they are potential life savers, in fact if you read my earlier posts on this and other threads, I have never said they should not be fitted where neccessary.
However they are not the be all and end all, nor are they the 'cure all' for all 'electrical ills', although they have their uses.
Since the 17th ed though, they have been pushed on to the domestic sector, a lot of sparks now use them as a 'magic bullet', for instance when the Zs is too high, and instead of either recalculating cable sizes or rectifying either a fault or design issues, just bung an RCD on it and it will fix it mentality, I feel over-reliance and misplaced trust has been placed on these devices. As others have said from the 16th ed and before we did not rely nearly so much on these devices.
Good luck with your experiment.
You are right, a large degree of faith is put on the inspector, I would always code a circuit supplying downstairs sockets with no rcd as a c2 now, recommend fitment of rcd or rcd socket nearest door. However the electrical installations were pretty safe without them, therefore I usually make recoomendations and observations but I will not insist on fuseboard replacement etc.
IMO bathrooms are pretty safe with good supplementary bonding in place and RCD's are regarded by some as a 'magic bullett' more so, reading on here, by the domestic sector.
You have to remember, houses (especially flats) were commonly wired with no RCD's right up to 2008, and were considered safe, they have not turned in deathtraps overnight!
I understand your stance in how you code installations without rcd's and its your choice as the inspector but.......
you need to consider the implications from automatically giving code 2's to rcd free installations.
many , many properties that are otherwise safe will recieve unsatifactory EICR's and will place a large financial burden on those on the recieving end.
just a thought.
@ P&S,
Wonder how many sparks would L-N loop impedance when wedging a 30ma rcd on an overly long/poor condition circuit, chances are with 1.0/1.0 T+E It may not even trip within the disconnection times on a short circuit!
BIFF- I'm advocating not automatically giving C2's to RCD free installs! I only apply what is in the regs, and even then I only usually reccommend an rcd socket to be fitted by the back door!
P&S,
If you do decide to carry out your experiment, FFS please wear suitable PPE, a full visor and gloves as a minimum, we don't want you to lose an eye, or get scadded off of exploding molten plastic.
You implied that you were with the comment
"I would always code a circuit supplying downstairs sockets with no rcd as C2 now"
Sorry but that goes against current guidance.
An actual exterior socket without rcd is a code 2 but any other indoor socket without rcd is a code 3.
P&S,
Good idea ! Wont need to actually hold the blow lamp, but will be holding the camera.
If i dont get called out, will try it Saturday morning.
Well, the guidance book I got says C2 for sockets likely to supply mobile equipment outdoors, c3 for others. If it was a flat without garden or upstairs flat I would c3 for all sockets, if it was a flat with garden would give C2 and reccomend fitting rcd/rcd socket. My company gives the guidance on the coding and this what they put, It was a Code 2 before the EICR but still pass. Now its a fail.
Why complicate the issue with all the talk of upstairs / downstairs flats , garden / no garden ?
Any socket near an opening window can be potentially used for outside with an extension lead.
And if theres a choice of 2 / 3 / 4 sockets near to an exterior door youre in effect condeming the whole ring main to a code 2 defect anyway.
Because an upstairs flat with no garden is unlikely to use equipment outside?
Its up to you what you code and I certainly don't disagree with your reasoning!
Fair enough mate , but it does worry me that your company gives you direction on how to code defects instead of letting you , the inspector , make that judgement call on a case by case basis.
If your company benefits from ensuing remedial works then a case for conflict of interests could be made against them , if you see
my point ?
my point ?
Umm.. certainly get your point, The advice they give is guidance though and I can, and regularly do, change it. They and especially I do not care about remedial works, I don't want to be doing them! I just test and record what I find, I never put down 'reccomend new board' even for wooden backed rewireables, as I believe most houses are fixable with a few minor repairs, and its not up to me to push for remedial work, only to record what I find
bureaucrazy,
Guitarist,
