should be using a pozi2 mate instead of a philips.
why is there so many different types anyway?
ph0,1,2,3
pz0,1,2,3
then
phg etc who carries all these bits with them honestly?
Me.
I have PZ0,1,2 and 3 in VDE drivers in my main box. Around a hundred different heads of all sorts that fit in my ratchet driver, PZ, PH, Torx, Allen, small sockets etc, and also a full set of security bits. Hardly takes up any space at all and invaluable sometimes.
I have always found the best tool for roofing bolts is your largest flat driver.
Me.
I have pz0,1,2. ph0,1,2 in vde
torx drivers as well and the usual multi bit sets a long with my trusty rachet set
Me.
Yep, everybody has a big yellow or a big red which occasionally needs a look at a grinder.
Boydy
Just out of interest, what are people using to bolt tray together with?
Hmmm..... That's what I thought. So we're happy to trust them for earth continuity of one thing, but not another?
As far as i remember, all construction/containment type bolts on this project is spec' stipulated to be stainless steel, can't remember the minimum grade mind... Same goes for specified electrical connections, eg,.... bolts/washers/ and nuts, all Stainless steel
So, that then HAS to beg the question of why is it that we get hung up over using Brass and also paying through the nose for it?!
Cable tray isn't required to have any earth continuity, or even be bonded.
Whereas the connection to the banjo is a connection of the CPC.
We test to confirm that all cable tray/cable basket/cable ladders etc, possess suitable earth continuity values throughout their length. I can't recall a single project that i've been involved on that hasn't called for earthed continuity of any of it's metal containment systems.
Roofing Bolts as Earthing studs
jim1976,
jamie-spark,
