Guest viewing is limited
Taking the gland plate off and replacing it with a brass one gets my vote for lots of SWAs into one DB.
Yep, I totally agree with that, the only thing I can think that might improve the situation is if you put the banjo on then a lock nut before putting it through the enclosure, otherwise on a metal dis board it does not improve the reliability of the earth
How would the locknut help?
A paint cutting/jagged/serrated washer might help.
I prefer to use piranha nuts these days unless I have a lot of SWA terminating in the same place.
I'm just considering if it comes loose, if its tight then it should have a good connection, if its loose it won't have a good connection whether it has a banjo or not but if it had a banjo with another locknut separate to the enclosure that could help, but the spring type washer is a good idea
All academic really unless you state whether the armour is the cpc as in a 2 core or a 4 core tp&n.
A 3 core used as an sp&n supply will have a core available for cpc use and the armour is then containment only.
Completely different scenarios.
Boydy.
In what way is it different, the armour must be connected to earth in an electrically and mechanically sound manner in both situations.
if you are going to go to the trouble of getting nylocks to go with them, why not just get proper bolts in the first place?
I think the main point is, is it part of the wiring system? Tray could be considered part of the wiring system, think about earthing cabinets containing electrical equipment, this would be to ensure the cabinet does not become live in the case of a fault, similarly for tray, though I would say the likelihood is low if the cables were all SWA.
Roofing Bolts as Earthing studs
Thread Tags
jim1976,
jamie-spark,
