Critical Feedback recent Consumer unit install Please. | Page 5 | on ElectriciansForums
Discuss Critical Feedback recent Consumer unit install Please. in the UK Electrical Forum area at ElectriciansForums.net
London
Hi, I would like to know how I could improve on this board. All opinions
[ElectriciansForums.net] Critical Feedback recent Consumer unit install Please.
welcome.
Hello MrShine94
From my perspective and at first glance the terminations other than the Live of the bottom 16A Rcbo ,they look very neat
Is the board spaced out from the Plyboard ? the cables seem to have been squashed between the unit and the Ply
Yes it does look a bit of an eyesore
In any event @magnoliafan89 I think you made a valid point in raising the question regards the earth etc. And I hope the reg I quoted will shed light on that question. Instead of being confused by statements of dismissal without any regs to back it up.
The reg was there in its entirety, you chose to publish part of it which inferred that the earth could Only enter collectively with other conductors which is incorrect and misleading to someone asking for advice, or am I still missing your point?
which is incorrect
Show me that in the regs or acknowledge you was wrong it is not misleading and the part left out in no way enlarges on the part quoted which does state, not infer, the earth should go in with the live and neutral, unless you are on a different timeline to me. Me? I am not inferring anything about anyone or anything you need not only to read but get some understanding.
It’s the same reg that says collectively or separate. You intimidated it had to be collectively and that’s my point. If the op glanded earth seperately your post would have led him to believe he’d made an error.
Reply to Critical Feedback recent Consumer unit install Please. in the UK Electrical Forum area at ElectriciansForums.net
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
The trunking on show there is only big enough for maybe 2 cables…. And a relatively new addition. Having an EICR done would give you an idea of...
