Latest Acquisition and it's mint. | on ElectriciansForums
Discuss Latest Acquisition and it's mint. in the Electrical Tools and Products area at ElectriciansForums.net
telectrix
Mentor
cheshire/staffordshire
H.W,Sullivan, type of Wheatstone Bridge . Son found it on faceache or some other anti-social gossip site. £15. Guess it's age to be about 80 -90 years. Lucien would have been able to give me some info., like what voltage battery etc, but any info appreciated.
Google tells me that the company was founder in 1897 , manufacturing telegraph machines.
  • [ElectriciansForums.net] Latest Acquisition and it's mint.
Looks like the meter has been "upgraded" on yours Tel,
V126 4.5v battery from the link below, unless your has been modded for 4 x "C" cell as pic below.
only problem is it's listed as "out of stock".
Very nice!
As you probably gathered it can measure resistances very accurately. Usually as accurately if not more accurately than a modern MFT. It can also do Murray loop tests to predict where a fault is.
Basically if a cable is faulting to earth, you join the conductors at the far end and measure the resistance as usual.
Then you'd switch to "Murray Loop", and the negative battery terminal would presumably need connecting to a good earth.
You'd then measure again. From these two values, and the formula in the manual, the distance along the line that the fault is can be calculated.
A Megger BR4 manual (which I found online as I have one) would fill in some of the blanks about the concepts.
fitted a 4.5V battery. sadly, no matter what I do with dials and switches, there's no response from the galvanometer: stuck on 0. it's not locked as the zero adjust moves the needle. going to open the box and see if there's anything glaring,
The most likely is that the galvanometer has become damaged.
As it's removable you could try testing it directly by cooking up something like this.
Make resistors P, Q, and R the same and S about half the value. It should move.
Or just stick an AA battery across it!
going to open it up tomorrow - see what's what. will gry above first option.
A bargain indeed if the below is anything to go by:
update.. opened it up and found this. galvo has deffo been updated as it has a PCB and on it there's a 8 legged microchip. there's 2 sets if leads coming off ending in 2 PP£ connectors, but no connection to the internals of the machine, and no apparent place for them to go. pointless fitting PP3/s as would just be a stand alone galvanometer . Any ideas???
further investigation finds that the 2 securing release pillars for the galvo are actually terminals, connected to both the galvo and the internal resistor banks. tomorrow will try and see if connecting 2 PP3s will get some life into it. if i read it right, maybe someone has modded it to use PP3s instead of the original battery, necessitating the removal of the meter to replace said batteries. weird.
What you are trying to reinstate is along these lines:
Hopefully that will set your bearings. (EDIT The middle button should say G and the bottom button should say B, sorry)
For testing purposes you could swap out the Galvanometer with a digital multimeter.
Here it is working....observe that with the DECADE set to 678 ohms, and a resistance of 678 ohms between X1 and X2 we get 0v in the middle:
For academic interest only, see this old thread of mine - it's exactly the same concept but yours is ready to roll, wheras a post office box needs a power source and a galvonometer/voltmeter connecting up.
RESULT.....Connected 2 x PP3 batteries to the galvo and got deflection. then added the 4.5V battery in the original position in the cabinet lid. a (nominal) 10K resistor then connected to X! and X2. Dials operated to give an almost Zero reading on the galvo, ( 1 division from absolute 0 ) and the setting showed 9.6K. Will try several different resistor values later. I have an organiser full of them, from 0.1 ohms to 10 Megohms.
The PP3s must be a requirement of the updated galvo.
The original picture looks similar to the PO ohmmeter 18a 'megger'. That used a 9v battery.
I know what you mean. The 18A is a beautiful machine. British Racing Green....
Very similar in function, it has an additional ingenious trick to help engineers find a broken (as opposed to shorted) cable location. You join broken to good at far end, plug headphones in, find a quiet spot and run some maths.
The 'upgrade' (still sold today) isn't quite as aesthetically pleasing....
Any collector of electrical junk should keep an eye on "GPO Tester" results on ebay. There's even a brand new complete 18C for £50 at the moment. (but my wife said "No" and I have enough bridge-based testers!)
That green one is very nice. Is it a military spec one?
The first edition manual says September 1965. It's stamped GPO so I think it was just prior to the plastic revolution and built to be hammered and last.
Bit premature with previous post saying result. readings are widely inaccurate e.g. a 6.8k resistor measures at 4.9k. a 3.3. k reads as 2.9k. could it be that the machine is reconfigured for 6V. the galvo has 2 x PP3s to operate the electronics.
Things to try:
-What does it measure with a dead short of low resistance between X1 and X2?
-try the resistors with an MFT to see if they are on the edge of their tolerance bands (gold 10%, silver 5%, none 20%).
-a normal multimeter on DC volts in place of the (originally) removable galvo.
The machine voltage actually doesn't matter, it's all about the calibrating the galvo so it reads zero when the bridge is balanced.
it does read 0, but the values on the dials are way out compared to multimeter, both digital and AVO8. will try the dead short as suggested then investigate further.
connected a very short piece of flex , measured on a low ohms meter at 0.020 ohms. Bridge says 0.8. across the terminals. Time to have a poke around inside I think..
Reply to Latest Acquisition and it's mint. in the Electrical Tools and Products area at ElectriciansForums.net
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
