Wiring up an immersion heater - help please | on ElectriciansForums
Discuss Wiring up an immersion heater - help please in the UK Electrical Forum area at ElectriciansForums.net
L
lofty84
Hi guys if anyone could help me out here I would really appreciate it. I've got to wired up a immersion heater. There is a switched fused spur mounted on the outside of the cupboard housing said immersion heater from this is a piece of flexed which need to be wired in. On top of the immersion heater is somewhere for the cables to go on the left is a heatrae terminal with a minus sin above it and on the right is a rdg terminal with a plus sign above it i take it live goes to the right and neutral to the left and the earth to the bi screw which says warning this alliance must be earthed. If so I will need some sort of earth crip and then a nut to tighten it down and make sites there a good solid connection. Any help greatly appreciated as there waiting on me to do It
[ElectriciansForums.net] Wiring up an immersion heater - help please
Hmmmmm
lofty, i cant believe so many people are taken in by your threads, your keyboard must be soaking wet with tears of laughter dropping from your eyes while you are typing!
Reply to Wiring up an immersion heater - help please in the UK Electrical Forum area at ElectriciansForums.net
What is the distance from the point outside the house to the shed?
