1.5mm to 4mm? | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss 1.5mm to 4mm? in the UK Electrical Forum area at ElectriciansForums.net
D Skelton
Mentor
Nearly Esteemed
Milton Keynes
Can anyone think of a product that is suitable for connecting a 1.5mm fine stranded flexible cable (ferruled of course) to a 4mm single core stranded cable within a galv conduit box?
I'd like to avoid using a screwed connector block if possible. Ideally this connection would be maintenance free also.
Physically you can class me as a grown man but mentally I'm far from it... :)
I'm one as well until Ive had a couple of scoops of whatever is going then I revert back to my childhood, dribbling, mumbling can't walk you know the sort of thing, happens to us all from time to time, makes me thing someone has been on the happy juice already today.
Slightly contentious, but what about using a yellow butt crimp with both cables in the same end? Heatshrink, obviously.
Whats up with insulation tape , twisty twisty wrappy wrappy
Dont use anything else than Wago's now. Never seen one burn out or over heat yet, have you? This may sound like advertising lol but have yo seen the new slimline push in Wago's? What a neat job you can get when connecting/extending in back boxes etc. Photo to follow next day or two.
I only use Wago too, either the 773 push ins for power, the 224s for lighting or the topjobs for panels. I've never tried the lever ones though, I shall be sure to report on my progress as it seems the 221s are the only Wago type connector that will do what I want them to do in this scenario.
I only use Wago too, either the 773 push ins for power, the 224s for lighting or the topjobs for panels. I've never tried the lever ones though, I shall be sure to report on my progress as it seems the 221s are the only Wago type connector that will do what I want it to do.
i used one of the lever ones on a crap light fitting today, 3 stranded 1.5mm core.
makes it a lot quicker because you dont need to ferrule them
Reply to 1.5mm to 4mm? in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
