2391 sum practical help | Page 4 | on ElectriciansForums
Discuss 2391 sum practical help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Anyone fancy giving their opinions for an awnser on the following question:
An insulation resistance test between live conductors on three individual single-phase circuits has been carried out. State one likely reason that is revealed for each of the following values, excluding loose connections and damaged cables.
a) 0.00M ohm - Dead short, eg tungsten bulb left in circuit?
b) 0.25M ohm - neon indicator left in line with switch on?
c) >299M ohm - Insulation resistance is satisfactory no fault??
Cheers.
brilliant stuff mate is going to help no end. Massive cheers
hiya m8 please clarify coz i think most of it i got from several books then made them into bullit points cant really remember to be honest it was at the time i was studying and it made sense to make this up both as an aid for me and at the time i ithought if i post it and it gets nitpicked then i will know exactly where i was going wrong i was put up as both a question for me and a possible aid for others if that makes sense hope this helps and ps any copyright issues sod it if you charge for using this at least buy a pen from this website free info is hard to come by so i just thought share and share alike
Wish had seen this before did my 2391. But thankfully passed anyway. I also spotted the absence of x2 faster for Pfc of 3phase. Also insulation testing of single phase can be done by blanket test.
Connect line & neutral together. Using 250Vdc, test to earth after doing all strap outs of electronic switches. This is fine as will not damage rcd/rcbos. But do rem to test all switches as described by bobby101...
Hi every one this is a very good post and given it top marks i am re taking on Feb 09 2012 after taking the exam in Oct 2011 all general info is relavent and to the point. This will be studied over the next coming days as i have been going over my course work and reading GN3.
With all the will in the world i am going to pass second time round!
Many thanks to all that has had input to this thread over the past year and it will be very interesting reading. Cheers Ian.
im doing it at end of march. i shall be prepared from posts on here and exam sucess, bs7671 , gne and 14 night classes, so i just adding to this post to tag onto usefull info
Can anyone shed some light on the remark process. ie. Do many results get overturned due to a challange via a remark, I done the December 11 examination and thought i performed well particularly in section B, I am thinking about putting in for a remark, what are peoples thoughts? has anyone heard of many results getting reversed??
Not sure mate
but you can only ask
I heard they do look at the exam aftwerwards to see if it met there criteria
but they do play about with the pass mark or making some exams slightly easier or harder but this could be just speculation and rumour
All I can say is contact C&G
why do you think they treated your paper unfairly
sometimes they make errors with the papers but i think they adjsut evryones equally so no one is disadvantaged
maybe someone with more knowledge of the examination system and complaints procedures etc can answer your question
good luck mate
I havnt seen the dec paper so dont know what was in it if someone amazingly got a copy you could go through it and answer again see if others agree with your answers
one of the forum members posts said he had done the same and on his way to the second exam got a phone call from his provider to say he passes the first lol so he turned round and went to celebrate
nice check sheet bobby, but remember all written instructions are subject to being amended by the IET. i would suggest this list is used in conjunction with bs7671 guidance note 3
Wow, brilliant!! I'm taking my 2391 in september, there's so much info to work on. The main thing is that i'm a little worried about the written test....I ain't that good at doing essays, also perhaps getting the wording right for C&G standard, but that might just mean I need to read over and over again. Either way I'm looking forward to doing it, if I fail first time, it might give me a chance know what's involved. Thanks Bobby101, great help. :cool4:
hi bobbi
im doing my practical tomorrow, this is a great read, thanks
One quick question tho, on continuity of main bonding, if ive read it right u said disconnect at the pipe end?
iv been disconnecting at the MET end and then placing one probe on the pipe and the other on the disconnected cable.
Would i be failing if i did it my way?
no mate you can disconeect it at either end
some say disconnect at MET and test between this and the bonded metalwork and some disconnect at the extraneous conductive part
either way has to be below 0.05ohms
goodluck mate
Reply to 2391 sum practical help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
