2391 sum practical help | Page 5 | on ElectriciansForums
Discuss 2391 sum practical help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Wow, brilliant!! I'm taking my 2391 in september, there's so much info to work on. The main thing is that i'm a little worried about the written test....I ain't that good at doing essays, also perhaps getting the wording right for C&G standard, but that might just mean I need to read over and over again. Either way I'm looking forward to doing it, if I fail first time, it might give me a chance know what's involved. Thanks Bobby101, great help. :cool4:
I think the examiners know that a lot of us will not get A level english and so are prepared to cut some slack. That said, it is imperative to get certain terminology right eg it's is an insulation resistance tester not a megger. Call it the wrong thing and I guarantee you will duff a mark
Keep on wading through GN3 till you know it inside out and back to front mate, you'll be fine:)
They've changed it to insulation resistance ohmmeter now :wink5:
yes mate it is wish someone would tell my tutors that i keep telling them same as low reading ohmmeter
and pscc tester and phase instead of line and live for the line also even though the neutral is also a live
direct and indirect contacts and they wonder why some of the students are struggling its even same on the course material and sample questions
fries my head i thought colleg was suposed to be the best route my experience is not and i have i had experience of all 3 routes lol
I'm an out of date dinosaur mate I still uses phases not lines:)
Guess what, i forgot, they, the good folks who write gn3, have changed it back to insulation resistance tester, as per the new amendment in chapter 4. It was IR ohm meter in the red edition lol
no way mate wish they would make there minds up
thanks for the heads up as i have jsut done 2330 302 and it was one of my questions
because of 2391 i learned insulaton resistance ohmeter
now back to IR tester they are getting money for old rope
i was surprised they changed it as i thought IR ohmmeter made sense.
Hi Grand, hope this helps, it's really rough but this was one of the first tasks we had to do in class of the systems. Also if you look in the On-Site Guide(red and green one) page 15 and 16, shows the physical connections of each of the system.
[ElectriciansForums.net] 2391 sum practical help
It kinda figured out that if you draw the normal circuit. ie showing the transformer, service cutout, CU and load, all you need then do is draw the earth path for each system because the actual circuit itself doesn't change, so you'll have three identical diagrams except for the earth path.
Hope this helps
Nick
knew I should have been on here last week - done the 2391 exam on thurdsay now got dreaded 6 to 8 weeks to wait for results !
Reply to 2391 sum practical help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
