Hi, have you ever submitted a certificate to Building control or an Insurance company, under your own name?Really? Any evidence of this? Or is it well they will try anything to get out getting things done mentality?
Discuss 2391 V NICEIC - Whats the point in 2391?? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
Not qualified. Not sure how to take thatIf you are a "qualifying supervisor" signing off certificates, but you aren't qualified to fill in the certificate, how does that work?
I have, even when the Insurance Co. requested that the EIC be from an NICEIC registered installer.Hi, have you ever submitted a certificate to Building control or an Insurance company, under your own name?
Hi Andy, so what you are saying, is that because you are a qualified electrician, you are automatically entitled to fill in a cert to cover the work you have undertaken. Why do you think that BS2391 was introduced? Its a level above 1st and 2nd fix installation. To gain 2391, you need to be able to understand the readings that your test equipment has just given you. You need to be able to correlate the readings, to what might be expected. I'm not trying to decry people from thinking that sparks should be confident in what they have installed, but 2391 gives you lots of mathematical equasions that can qualify your readings. Its not that simple. Thats why 2391 exists!
Hi, so look at the above posts, to find a guy that is a QS, but doesn't have 2391!The 2391 qualification was introduced (as I have already pointed out) at the behest of the NICEIC as a requirement for the role of QS.
As for signing off their own work.
Any electrician working in accordance with BS7671 (regardless of qualifications), must be able to sign off their work.
Why would I? It’s a pointless excercise, you actually think they will do anything with it other than lose it?Hi, have you ever submitted a certificate to Building control or an Insurance company, under your own name?
Do you think I would benefit from having it.Hi, so look at the above posts, to find a guy that is a QS, but doesn't have 2391!
Fair comment. Try joinin NIC or Elecsa without it.Um.... all that knowledge comes with standard training, at least it did with mine. Why testing exists, how to test, how to interpret results, all the equations and physics behind testing and results, how to fill in a cert etc.
I'm sorry but your assertion that the 2391 or equivalent quals are required to be able to test and certificate work is nonsense and you won't be able to back that up with anything more than opinion.
So read through the previous posts.Hi, so look at the above posts, to find a guy that is a QS, but doesn't have 2391!
It's not a British Standard, it's merely a qualification. Referring to it as BS2391 is incorrect.Hi Andy, so what you are saying, is that because you are a qualified electrician, you are automatically entitled to fill in a cert to cover the work you have undertaken. Why do you think that BS2391 was introduced? Its a level above 1st and 2nd fix installation. To gain 2391, you need to be able to understand the readings that your test equipment has just given you. You need to be able to correlate the readings, to what might be expected. I'm not trying to decry people from thinking that sparks should be confident in what they have installed, but 2391 gives you lots of mathematical equasions that can qualify your readings. Its not that simple. Thats why 2391 exists!
From what I understand, the invigilators are quite hot on correct terminology in the 2391 exam.It's not a British Standard, it's merely a qualification. Referring to it as BS2391 is incorrect.
If the job that you are in allows you to be a qualifying officer, without holding 2391, then don't rock the boat.Do you think I would benefit from having it.
Reply to 2391 V NICEIC - Whats the point in 2391?? in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
