63 Amp Isolator | Page 4 | on ElectriciansForums
Discuss 63 Amp Isolator in the UK Electrical Forum area at ElectriciansForums.net
Surrey
I'm running a 63A supply for a cooker and need to have a local isolator.
Apart from having a 63A main switch in a small enclosure, is there any thing else I could use which is discreet to put in the back of a cupboard.
If the manufacturers instructions call for DP isolation, then that is required to comply with regs.
Can't disagree with that, but then again, if the instructions call for a smiley face to be drawn on every one of their accessories then guess what... Lol. Kinda irrelevant to this debate but I see where you're going :D
Irrelevant? DP isolation isn't really in the same category as a smiley face....
Just look at the whole damned 3 amp fan fusing fiasco to see how important following manufacturers instructions are nowadays.
Because it would be unreasonable to expect danger to occur at the cooker any more so that at any other domestic accessory or appliance. Also, if the worst happened, the cooker will have an integral on/off switch which is readily accessible and durably placed so as to prevent danger.
Perhaps the most relevant reason however that emergency switching wouldn't apply to a domestic cooker is the fact that it is not classed as machinery! It is a COOKER.
I always fit one of these next to cookers in a domestic environment:
[ElectriciansForums.net] 63 Amp Isolator
You can never be too careful.
Hmm, yes. I also understand that most manufacturers instructions are either non existent or meaningless! Hell the last cooker I connected I seem to remember it asking me to use 6mm HR flex?!?
I don't think I've ever seen any manufacturers instructions for cookers that deal with anything more than the size of cable required and the arrangement of the final termination into the cooker itself.
If you would code a cooker with no local switch then you've no business carrying out EICRs.
A mention would be all it would warrant, if that.
Think you need to calm down a bit. I never said anything about your work.
Mike 66 said...go on commit yourself would you install a cooker without an isolator.
i was posting in response of that.
Who are you to jump on me saying I have no business doing EICRs. The whole point of an EICR is to give MY opinions on the condition of an installation. MY opinion.
Originally Posted by Kate
I would always install an isolation switch to a cooker. I will mark as an observation/issue if a cooker had no isolation too
I didn't say I would code it. I would mark it on observation sheet which is same as 'mentioning it'
Because you would code a cooker with no local isolation when it warrants no code whatsoever. Ok, maybe my response was a bit harsh, I was just getting agitated by the whole 'ooooh, that's not very professional' attitude incinuated by others. My intention was never to 'jump' on you.
Still, if I found out an electrician had coded my work and it was unwarranted, they would at best be receiving a very stiff letter from me!
I just get the impression that there are a great many sparks out there that rely on dogma for an education rather than regulatory requirements bearing in mind that when carrying out EICRs we are testing and inspecting to BS 7671, not best practice. Anyone who doesn't know this indeed has NO business carrying out EICRs.
Edit: as I said anyone who would code it has no business carrying out EICRs then my reply clearly doesn't include you as you have now stated you would only mention it. Therefore no 'jumping' has occured! :)
Just curious here as I ain't domestic spark.................and not taking sides either:)
How would you guys, who are discussing the matter with Mr.Skelton, isolate a lighting circuit?
Cooker..........230v
Lights...........230v.
both will kill you if you let it.
Do you put a local isolator on each lighting circuit or each light?
I wouldn't code it. I would just mention it on the observation sheet. A cover my a$$ if there was ever a cooker fire after my EICR.
In my experience of the general public sometimes only one person in a household actually knows where the DB is! If the worst happened I like an iso switch near cooker area.
Landlords insurance more often than not requires local iso near cooker. So does council. 90% of my EICRs are for one of these two so I mention it on obs sheet. Also I dont deal direct with owners, usually estate agent etc.
Reply to 63 Amp Isolator in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
