A brilliant young boy was applying for a job with the railways. The interviewer asked him: "Do you know how to use the equipment?" "Yes", the boy replied. "Then what would you do if you realized that 2 trains, one from this station and one from the next were going to crash because they were on the same track?" The young applicant thought and replied "I'd press the button to change the points without hesitation." "What if the button was frozen and wouldn't work?" "I'd run outside and pull the lever to change the points manually" "And if the lever was broken?" "I'd get on the phone to the next station and tell them to change the points," he replied. "And if the phone was broken and needed an electrician to fix it?" The boy thought about that one. "I'd run into town and get my uncle" "Is your uncle an electrician?" "No, but he's never seen a train crash before
SKILL SAW: A portable cutting tool used to make boards too short.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh ****'.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
ADJUSTABLE SPANNER: Used to round off bolt heads. Sometimes used for the creation of blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VICE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for igniting various flammable objects in your shed and creating a fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles to test wall integrity. Very effective for digit removal !!
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut large pieces into smaller pieces that more easily fit into the waste bin after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of all the crap you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
COMMON SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PVC PIPE CUTTER: A tool used to make plastic pipe too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
BIGGER HAMMER: Same as a normal hammer but larger in size and weight. Used to make things that don't fit, fit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door. Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund cheques, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON OF A BITCH TOOL: Any handy tool that you grab and throw across the garage while yelling 'Son of a bitch' at the top of your lungs. It is also, most often, the next tool that you will need:innocent:
"You have been charged with assaulting your wife with a fish," the judge said. "Do you have anything to say in your defense?"
"Yes," I replied, "It's cods wallop."
The wife wanted to try a bit of role reversal in the bedroom.
I hated it though, I just sat there half the night with my arms folded while she was down the pub.
A man and wife are in bed one night when suddenly there's a knock at the door. Bleary eyed, the man staggers down the stairs mumbling profanities and opens the front door to see an old man.
"Im sorry to have woken you up but i was wondering if you can help me by giving me a bit of a push?" "what??" Replied the man, "you woke me ip at two in the morning for that? Get lost. I have work in the morning" He slams the door and marches back upstairs. As he gets into bed his wife enquires as to who was at the door.
"Oh, some old fella wanting a push. At this time of night" he snapped.
"And you didn't help him?" His wife asked, "What if it were me and our car broke down. Do you think you'd be happy knowing someone couldn't be bothered to help me? I think you should go out there and help him right now"
"Oh alright" he muttered. He put on his housecoat and the nearest pair of shoes and went back downstairs to see if the man was still there.
Upon getting outside, he couldn't see the man or his car anywhere. "Hello!? Are you still there?" He shouted.
"Im over here" a voice called out. "on the swings"
These fit so well they should be in a dictionary.
ADULT:
A person who has stopped growing at both ends
and is now growing in the middle.
BEAUTY PARLOUR:
A place where women curl up and dye.
CHICKENS:
The only animals you eat before they are born and after they are dead.
COMMITTEE:
A body that keeps minutes and wastes hours.
DUST:
Mud with the juice squeezed out.
EGOTIST:
Someone who is usually me-deep in conversation.
HANDKERCHIEF:
Cold Storage..
INFLATION:
Cutting money in half without damaging the paper.
MOSQUITO:
An insect that makes you like flies better.
RAISIN:
A grape with a sunburn.
SECRET:
Something you tell to one person at a time.
SKELETON:
A bunch of bones with the person scraped off.
TOOTHACHE:
The pain that drives you to extraction.
TOMORROW:
One of the greatest labour saving devices of today.
YAWN:
An honest opinion openly expressed.
[TD="class: ReadMsgHeaderCol1"][/TD]
[TD="class: ReadMsgHeaderCol1"] [/TD]
A handful of 7 year old children were asked, 'what they thought of beer.'
Tim- 'I think beer must be good. My dad says the more beer he drinks the prettier my mom gets.'
Melanie - 'Beer makes my dad sleepy and we get to watch what we want on television when he is asleep, so beer is nice.'
Grady - 'My Mom gets funny when she drinks it and takes her top off at parties.'
Toby - 'My Mom and Dad talk funny when they drink beer and the more they drink the more they give kisses to each other, which is a good thing.'
Sarah - 'My Dad gets funny on beer. He is funny. He also wets his pants sometimes, so he shouldn't have too much.'
Lilly - 'My Dad loves beer. The more he drinks, the better he dances. One time he danced right into the pool.'
Ethan - 'I don't like beer very much. Every time Dad drinks it, he burns the sausages on the barbecue and they taste disgusting.'
Mary - 'I think beer tastes bitter and I don't like it. Mom likes it, but she gets tired and leans on guys and they have to help her to the bedroom for a quick nap. When they come back, she is all perky and happy, and the guys are all tired out.'
Shirley - 'I give Dad's beer to the dog and he goes to sleep.'
Brittney - 'I don't like beer, but mom says it helps you get the guys you want, so I'll have to learn to like it.'
Jack - 'My Mom drinks beer and she says silly things and picks on my father. Whenever she drinks beer she yells at Dad and tells him to go bury his bone down the street again, but that doesn't make any sense.'
Fergie - 'My mom never drinks beer when dad is home, but he sometimes does. Then she yells at him when it makes him want to smooch. Mom only drinks beer when dad is away. When it makes her want to smooch, she will do it with everybody, even the Pizza guy, and he is weird.'
Alice - 'My sister told me you have to drink your own weight in beer before you start to like it. She has some ways to go yet, I think. The guys usually ignore her until they have had a whole lot of beer, then they get nice and play with her.'
Brad - 'Beer tastes disgusting. My brother told me it makes you think the girls are pretty. With his girlfriend I would need an awful lot of beer.'
A traveling salesman, in the middle of his two-week stint on the road, walks into a ----- house. The salesman whips out $300.00 and hands it to the Madam of the house.
"Give me the WORST lay you have here." he says.
The Madam, looking confused, says, "But sir, for this kind of money, you can have one of my very BEST girls."
The salesman, not to be discouraged, says, "Please, I just want the WORST piece of --- in the house."
The Madam, now getting a bit upset replies, "Sir, for $300.00, you could get the best lay of your life."
Sheepishly the salesman says, "I don't want the best lay of my life. I'm not horny - I'm homesick!"
After living in Shanghai for 50 years a Chinese man decides to move to Australia.
He buys a small piece of land near Mt Isa.
A few days after moving in, the friendly Aussie neighbour decides to go across and welcome the
new guy to the region.
He goes next door but on his way up the drive-way he sees the Chinese man running around his
front yard chasing about 10 hens.
Not wanting to interrupt any Chinese custom, he decides to put the welcome on hold for the day.
The next day, he decides to try again, but just as he is about to knock on the front door, he looks through
the window and sees the Chinese man urinate into a glass and then drink it.
Not wanting to interrupt another Chinese custom, he decides to put the welcome on hold for yet another day.
A day later he decides to give it one last go, but on his way next door, he sees the Chinese man leading a bull
down the drive-way, pause, and then put an ear next to the bull's bum.
The Aussie bloke can't handle this, so he goes up to the Chinese man and says, 'Jeez Mate, what the hell is it
with your Chinese customs ? I come over to welcome you to the neighbourhood, and see you running around
the yard after hens. The next day you are ****ing in a glass and drinking it, and then today you have your head
so close to that bull's arse, it could just about **** on you.'
The Chinese man is very taken back and says, ' Sorry sir, you no understand.. These no Chinese customs I
doing, these Australian Customs.''
What do you mean mate' says the Aussie, 'Those aren't Australian customs................
'Yes they are', replied the Chinese man, 'travel agent man say to become true blue Australian, I must learn
chase chicks, drink ****, and listen to bull ****.
When Charles deGaulle decided to retire from public life, the American ambassador and his wife threw a gala dinner party in his honor. At the dinner table the Ambassador's wife was talking with Madame deGaulle.
"Your husband has been such a prominent public figure, such a presence on the French and International scene for so many years! How quiet retirement will seem in comparison. What are you most looking forward to in these retirement years?"
"A penis," replied Madame deGaulle.
A huge hush fell over the table. Everyone heard her answer...and no one knew what to say next.
Finally, Le Grand Charles leaned over to his wife and said,
"Ma cherie, I believe zee Americans pronounce zat word, 'appiness."
In a recent On-line poll 38,562 men across the UK were asked to identify a woman's ultimate fantasy.
98.8% of the respondents said that a woman's ultimate fantasy is to have two men at once.
While this has been verified by a recent sociological study, it appears that most men do not realize that in this fantasy, one man is cooking and the other is cleaning
A new jokes thread for your amusement.
Electrician Talk Forum
MarkieSparkie,
Mike Johnson,
