Absolutely no earth for lighting circuit. | Page 2 | on ElectriciansForums
Discuss Absolutely no earth for lighting circuit. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i cannot find a reg that dictates the practice of splitting up circuits as to minimise inconvienience
531.2.4 (bgb) is another related to RCD's
Sorry to top up an old post but I've just had a similar situation where I've changed a CU for someone as it was an old metal one with re-wirable fuses, the cover was missing and there were none of the barriers inside! There was also no cpc to the lighting just single black and reds. I've explained to the lady that she either needs to have the lighting rewired or change the light fittings to class 2. She is going to have the light fittings changed, I'm going to put it all strongly in writing with the certificate but where do we stand if she'd have refused? surely it's better that by fitting a new board with rcd protection we've made the situation safer?
If the metal clad board was part of a full conduit installation,perhaps the installation is now less safe ( was it full conduit ?)
Reliance may now be on an rcd on a circuit with no earth,whereas previously the circuit may have had adequate protection via the conduit and the rewireable fuse
I am inquisitive to ask
quote
Was this the main or sole reason for making this decision ?
An NIC engineer once told me dont think u r making an installation safer cus of a board change. It was cus of the disconnection times and the current needed 2 trip an RCD. Makes ya think.
So long as you make the landlord aware of your concerns, note them on your cert and class it as a C1 with an unsatisfactory overall opinion, it's not your problem and no longer your responsibility. Provide him with the options to rectify the issue, the easiest being making the circuit a class II, the most beneficial would be to install a cpc. Advise that it would be wise to add a condition to the rental agreement that tenants are not permitted to alter the accessory's to the circuit where a cpc is not provided.
I would be interested to know what the outcome is when you inform them that once in possession of your advice it is their responsibility.
matey. This thread is neatly 4 years old!
This thread is from 2012 so I think it's more a case of what the outcome was rather than what it will be!
But in response to your post:
Recording a C1 observation on an EIC is not acceptable.
It is his problem because he fitted a new CU to the installation and re-energised it in full knowledge that the circuit was in a potentially dangerous condition.
You cannot make singles in steel conduit into a double insulated installation without replacing with double insulated singles.
What are double-insulated singles? In fact, what is a double-insulated cable?
Nonetheless, an installation with a protective measure of double or reinforced insulation is highly specialist and would not be found in any domestic premises!
Double insulated singles would be single core cables with double insulation ;) don't ask me where to buy them though as I've never yet come across any.
That is my point.
Reply to Absolutely no earth for lighting circuit. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
I created a voltage drop spreadsheet for this sort of thing. I used to use it to calculate the drop when designing regular 230V lighting circuits...
