E
eskimo39
As there seems to be quite a bit of interest the last few days in Wago and Wagobox I decided to see what all the fuss was about and have had a look at price comparisons.
If I want to spur a socket off a ring I could use :
I also looked at fitting downlighters, I pay 70p per choc box and a strip of 3 connectors costs around 18p, again compared to £2.27 this seems a lot if I am fitting 100 downlighters.
Finally I tend to join out neutrals in the back of a switch and the '3 Pole lever cage clamp' looks ideal, is this o.k to use, as at 20p each does not seem too drastic in price. The 'Pushwire' ones are even cheaper but am I correct in saying you cannot remove the wires once fitted?
Thanks in advance
- 30a junction box at around 90p
- 3 x 3 Pole Pushwire Terminal blocks at 24p each (72p total) enclosed in a wagobox at £1.55
Thanks in advance
