Any one do the 2391 tonight? | Page 2 | on ElectriciansForums
Discuss Any one do the 2391 tonight? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good luck guys, I waited 10 weeks for my results. Its worse that the actual test. You start second, third and fourth guessing yourself. You will remember questions and answers one day, then a week later youll remember the same question but with a diiferent answer. Just hope its a big brown envelope with the words " Do not bend " on it that comes through the door then you know youve passed. When I did it, I was told it was 80% to pass, well thats what our tutor told us.
Jay
I did the 2391 last night as well.
Cant believe how fast the 2 and half hours went. Thought the 20 section A questions were ok, although i know i messed a few up.
Disappointed with ques 24 and 25, more or less the same lists.
I dont know but i would have thought the pass mark was about 75/80%.
Jay
I don't mind admitting that, at the age of 41, I wept when it arrived.
What a big girl :)
I actually found out over the phone first. I had waited around 10 weeks and I couldnt keep my knickers on any more, so I phoned the training centre where I did it and it had been sat there for a week and the woman told me I had passed. I didnt cry though, ( Spartykus ), but I had the biggest smile ever for the whole day and a good old drink later that night. The big brown envelope then turned up a week later. lol
Jay
umm RCBO i didnt disconnect on IR test, t
he RCD trip time in section A i put 300mA but changed to 500ms last min for sum stupid reason.
had to add at the bottom of my IR procedure ' switch all two way switches & intermediate switches then repeat procedure above'
I finished section A in 20 mins that was real easy, especially when we literally were taking about the characteristics of a low resistance ohm meter outside the room door!
The Phase rotation test location got me,
Yeah the SWA Cable Tray Q in section B was a bugger.
Finished with 40 mins spare. loved the ring continuity Q, i got my crayons out for that too, and earth fault loop path an easy 15 points!
A Classic moment, one of the lads called the lecturer over and said, "what should i do about this i read the question wrong and i done a radial instead of ring test, SH..1t)
everyone laughed 15 mins left i could hear the pen burning!
Trade skills 4 U told me it was a 50% pass mark - I am still in disbelief......
When I questioned it, I got told he was marking it as he was an external C&G assessor.
Fingers crossed )
The 2391-10 is a floating passmark, the papers are marked before the passmark is allocated.
Reply to Any one do the 2391 tonight? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
