Been told my install is dangerous! Is it? (with pic) | Page 2 | on ElectriciansForums
Discuss Been told my install is dangerous! Is it? (with pic) in the Australia area at ElectriciansForums.net
cable_guy
Hi all,
I'm new here, so hi!
I know nothing about electrics, but am thinking of selling my house and I'm hoping someone can help me please.
A couple of years ago I had my electric shower fixed, and in doing so the electrician saw my main install and said that he shouldn't really touch it as it's too old. Don't think he was trying to con me as the electric shower was an insurance job so he knew he wasn't going to get any money out of me etc......
Does this look like I should get it upgraded please?
If so, any idea how much it'd cost me to do?
Many thanks in advance.
Possible nick but i would suggest if you look realy hard i think that its a twin and you can just see it pass the top corner of the cut out fixing board and continue down the celing.
But hey im sure it wouldnt be the fist time either us have traced a cable wron.
Jim
is this picture any better? sorry about the shoddy pic its quite hard to take photos in there!
eskimo39 - There aren't any green or yellow cables I can see, and I live in the middle of a city. ÂŁ400-600 best case :eek: bang goes my recessed spot lights I think then!!!
Well there is one thing i will say ,call your electrical supplier and get them to check see if the earth has been installed its labled as a PME (TNCS) so it should be ,there is no visable earth comming from the cutout , but seeing the closer picture and with the old obsolete RCD im now sure its a TT system ,having said that the main cable looks like its relativly new ,concientric type
Black rubber if your house has it ,unfortunatly it will need a rewire , black rubber disintegrates rapidy , it tends to get brittle and basically crumbles away , may be perfectly alright , but in the many cases ive seen it may not
Its good luck with that photo
The pme earth is available,which is a very good start
4.5 and 6 hundred for a consumer unit change :eek:
I am shocked as well.you wouldn't get those sort of prices in my 3rd world area
250 maximum,city slicker cprices "say another ton"
My I sometimes wish I lived in a city :)
In answer to the cable type
They are now trying to frighten your bank manager :)
If it is Vir,then the installation will become an expensive pain
I suspect the shower spark would have told you if that were the case
An onsite assessment by a local spark may be your best way forward
I dont go much for your method of looking for a spark
Perhaps go on the competent person website and search for an electrician who is registered for Periodic inspection by the schemes
Im affraid the electric board are no better than the rest of us if they fitted it on a friday and its all they had in the van it is more than possible you have a TT and a TNCS cut out.
Your visible cables look painted at top of CCU (fuse box) so you may not be able to see them.
Im affraid they are all right though you need a sparks to have a look at it try and find one recommended by a friend.
Good luck
Jim
Hi Des, thanks for the advice. I'm not sure what you mean, is there some sort of registered professional electrician website I've not seen?
I have submitted my tender to ratedpeople.com to get sparkies out to have a closer look at it to see what they will charge, do you think thats a good idea?
Hi cable guy if you go on the elecsa nic napit websites you can search for a regestered spark have alook may be helpful
cheers, a lad from a firm in crewe has got back in touch with me already about coming to have a look on Wednesday, but searching for his company's name on NICEIC doesn't say that he's on there!! Should I ask to see any of his papers etc if I want him to do the work?
He may be registered with another body i.e. Elecsa or Napit these are similar to NICEIC only the NICEIC are more known however as long as he is registered for one of these schemes for any work carried out if you agree for him to put right anything that needs doing otherwise you will have to pay for Local Authority Building Control to check the work complies with Part P regulations.
Check out my website for more info on Part P or visit Welcome to ELECSA or Part P | Electricians | Building Regulations - NAPIT UK
The niceic is just one of the schemes
Look at the communities and local government website for competent persons
State where you live and a list of people from the 3 main schemes will be available
Click on the individuals name and check thier scope with the scheme providor as to whether they are covered for test and inspection(pir)
There are various levels of competence
Full scope(they can install and self certify all domestic installations
Full scope with Pir approval (they can do a pir under the banner of the scheme)
Defined scope These are other trades who can do work associated with their tade example Plummers kitchen fitters etc
The defined scope members are prone to taking on work they are not permitted because "they have their part p" or some other useless jargon that theys spout
The main schemes are niceic,napit,elecsa(eca)
If you employ someone who is not registered then by law you have to inform bulding control and follow their procedure as regards notifiable work under part p of the building regs and pay a large fee
If they are not listed, then they are not registered,so chose carefully
Hi all,
No idea, I have the exact same electrical layout in my garage though
Try searching on HERE.
This covers all the schemes
Reply to Been told my install is dangerous! Is it? (with pic) in the Australia area at ElectriciansForums.net
2 3
Hi everyone, I’m looking for a bit of advice as to what courses to take to become fully qualified (having been out of the trade for around 14...
