BELL WIRE FOR RING PRO DOOR BELL | on ElectriciansForums
Discuss BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
LEEBOY
suffolk
HI GUYS AND GIRLS,
LOOKING TO INSTALL A RING PRO DOORBELL WHICH IS POWERED BY A 3 PIN UK TRANSFORMER NOT FROM A CU .
MY QUESTION IS WHAT BELL WIRE TO USE PLEASE.
REGARDS LEE
HI GUYS AND GIRLS,
REGARDS LEE
What voltage does the bell operate on?
The ring pro website recommend 20awg bell wire which is obviously american gauge wire but haven't got a clue as where to start with uk bell wire.
regards lee
thats great, thanks ever so much for your help. Is there any problems chasing the bell wire into a brick wall or surface mount only.
regards lee
thanks for all your help. Clicking on the link brings me to a general search so dam i safe to say most standard bell wire will be ok.
regards lee
regards lee
No reason why you cannot chase it into a brick wall but check it functions before you fill the chases as the small conductor is fragile. You can surface fix but the clips are small and are okay fixing to wood but brickwork they will be hard to fix and because the nail is short it is liable to fall out of plaster work finishes.
thanks ever so much for your help. Because its small i wanted to chase it as opposed to fixing it as it seems it would be fiddly and probably damage it along the way. thanks again for all your advice today.
just have a look on the ring website, they have all the info you need to install one and if you want it mains powered instead of battery it can give you a list of compatible powered door bell chimes that can feed the power to the ring device itself
personally, i'd use a bit of belden cable. it's tough as pete999's false teeth. :D
Reply to BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
Yes that will do the job - presuming there is a battery in it and it's working Ok! Turn the rotary knob one click to the V setting as you say...
The light may have a permanent supply already inside it if you are lucky.
