BELL WIRE FOR RING PRO DOOR BELL | Page 2 | on ElectriciansForums
Discuss BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
Thanks all. Forgot to say there is no existing bell cable or transformer at the CU hence why I'm going with the mains plug in transformer.
regards lee
regards lee
Of course you could always use a wireless bell.
You don't have to use thin bell wire, if you plan to bury it in plaster I'd consider something more robust that includes an outer sheath.
regards lee
Where are you intending to fit the transformer Lee?
Hi PETE,
TRANSFORMER IS ALL OF TWO METRES FROM THE FRONT DOOR , SJD SUGGESTED NOT USING BELL WIRE
So you intend plugging it into a socket, run the output cable up the the bell and from the bell to the push, correct?
HI PETE,
NO BELL TO WIRE FROM OR WIRE TO. I HAVE NO EXISTING BELL TRANSFORMER OR PUSH AT THE DOOR. THE PRO DOES COME SUPPLIED WITH A CU TRANSFORMER BUT I WONT MESS AROUND WITH ANYTHING AT THE CU HENCE THE STAND ALONE TRANSFORMER PLUGGED INTO A SOCKET THEN POWERED FROM THERE TO THE BELL, THE WHOLE DISTANCE IS ABOUT TWO METRES, REGARDS LEE
HI PETE,
It may be age, but you have lost me Lee how does this pro bell thingy work then
Reply to BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
Yes that will do the job - presuming there is a battery in it and it's working Ok! Turn the rotary knob one click to the V setting as you say...
The light may have a permanent supply already inside it if you are lucky.
