BELL WIRE FOR RING PRO DOOR BELL | Page 3 | on ElectriciansForums
Discuss BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
Hi PETE, OK HERE GOES :IF YOU HAVE AN EXISTING BELL/TRANSFORMER RUN FROM CU ITS A TWO MINUTE OF PUTTING IN A SUPPLIED CABLE IN THE EXISTING BELL AND WIRE UP BELL AT THE DOOR JOBS A GOOD UN. THE PRO RUNS AT 24V AC AND PRETTY MUCH ALL UK BELL TRANSFOMRERS RUN 12V AND THATS NOT ENOUGH SO SUPPLIED CABLE HELPS YOU USE EXISTING BELL BUT THE SUPPLIED DIN RAIL TRANSFORMER MUST BE CHANGED AT THE CU . I HAVE NEITHER EXISTING BELL OR TRANSFORMER AT THE CU , SO THE QUICKEST WAY FOR ME AND SAFE WAY IS THE BELL CAN BE RUN FROM A MAINS PLUGGED IN TRANSFORMER . TRANSFORMER TO RING PRO AND READY TO GO ,INCLUDED IS A WIRELESS CHIME AND IS SET UP OVER WIFI WITH THE BELL . REGARDS LEE
Thanks, so your original question what bell wire to use and buried in plaster, ordinary bell wire will be OK as per my original post.
THANKS PETE FOR ALL YOUR INPUT OVER THE LAST COUPLE OF DAYS.
REGARDS LEE
Hi Lee, I am also thinking of installing my ring pro with a plug in transformer. I am in the uk also, could you give me any advice on your installation, how it went, also could I ask you which plug in transformer did you use and where you purchased it from, as I am having difficulty in locating one to use. Thanks.
I think Lee is long gone why don't you start a new thread.
Reply to BELL WIRE FOR RING PRO DOOR BELL in the The Welcome Forum area at ElectriciansForums.net
Yes that will do the job - presuming there is a battery in it and it's working Ok! Turn the rotary knob one click to the V setting as you say...
The light may have a permanent supply already inside it if you are lucky.
