Blanks missing from CU in 2 senarios | Page 4 | on ElectriciansForums
Discuss Blanks missing from CU in 2 senarios in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Risk assessment, method statement...…..and screw the cover back....? ;)
Enclosure had the threads missing from the plastic back box or I’d have just fixed it back.
Presumably it’s been like that from day 1 and nobody could be arsed to change the surface box so left it.
Building was built around 2004/5 as it’s brown/blue coloured wiring but the consumer units are split load 16th edition stranded
Building was built around 2004/5 as it’s brown/blue coloured wiring but the consumer units are split load 16th edition stranded so will have been like that since installed
I personally think every scenario is different.
Accessibility comes into it in my opinion.
For instance today I had a fused spur in the loft area supplying the tv amplifier for a small block of flats , cover not screwed back so exposed live parts.
Normally I would c1 this however the loft area is only accessible by step ladders ( non fitted internally) and the loft cover can only be opened by a hex key.
I did not c1 this in this scenario.
No light, hands groping round in the dark?? Ladder or not C1 all day long.
Your not there to do any favours, your there to cover YOUR arse not theirs.
Any live working requires Risk assesment and method statements. Not just restricted access. As I said you shouldnt be working live not cant work live.
All works require RAMS. Not just live working.
In order to test and fault find you will almost certainly have to work live.
It’s nowhere near the loft hatch.
You need to crawl in and across the walk boards to access it.
I never said I didn’t code it (C2) incase you care.
It’s my discretion as the inspector and no body else’s.
Your arse too.
With this type of thing you have to reword your decision in the patronising tones of a prosecution barrister.
But as you rightly say it’s your call.
So all these Code 1s people dish out do you give notification of it on the day in writing.
Email the EICR to bill payer
For urgent attention in subject box if C1s.
Chat with site if it’s something horrendous, don’t lick that bit kind of chat, you know the one.
Your arse too.
Again there’s a potential of danger but I can’t see an immediate risk to life hence no c1
It is a loft which is locked at a height in a block of communal flats to which no one has access.
I’ll live with my judgement and will sleep at night.
The report has an unsatisfactory outcome amongst other contributing factors so I believe my arse is indeed covered.
Reply to Blanks missing from CU in 2 senarios in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
