Cable size | Page 17 | on ElectriciansForums
Guest viewing is limited
Discuss Cable size in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
I am going to be connecting an out door power supply, away from the building, its all metal casing.
The supply is 10mm, I am using a 3 core SWA for part of the run, the inside part was going to be in twin and earth, but then I was just thinking, going on table 54.8 section 544.1, am I looking into this too much or does it need to have a 10mm earth as its extraneous metal which is fixed into the ground?
In which case I was just thinking of running 3x 10mm inside the building so the earth is 10mm too to them comply with min size of bonding conductor.
I am right to make it 10mm throughout the entire run aren't i?
I cannot see the picture clearly enough, give me a moment to have a closer look
Edit: Nope, still cannot make it out properly, I will have to take your word on it lol
But they each appear to have a single phase circuit going out to a meter then coming back, all through the same hole so there shouldn't be any reason to change them.
yes the ones going out the side are for the meters, which I will be putting another one in for them the same as it happens.
The ones at the bottom, ill see if I can fix that and get it through one hole etc..
Does this help...
[ElectriciansForums.net] Cable size[ElectriciansForums.net] Cable size[ElectriciansForums.net] Cable size
But installing them a little bit more sensibly I assume? Lol, I don't think they could have made more of a hash of that if they'd tried.
I can't see why they would the neutral out to the meter and then bring it back into the board to bodge it onto the outgoing cable? And as for the bodge and tape joints??
I thought the tape was just for ID??? Daz
Reply to Cable size in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
Recommended Sponsor News
Hi everyone,
