Cables to run accross concrete floor
I will have to get tails from meter more than 15m to consumer unit.
Will also gave to either 12m through concrete floor or through a double skin wall to a room with suspended floor for 10m and back 5m through concrete floor. Whats the best way to do and protect this within regs etc.
I’ve just re-read the full thread, Sidekick do you consider yourself competent to do this job? You seem to have no idea about terminating the cable. Over the years I’ve had numerous earth faults caused by inexperienced people making off the glands.
Seriously consider what you’re doing, 25mm 3c SWA isn’t going to be cheap to replace if you damage it glanding it off.
Hi Guitarist and Tony,
Firstly thankyou for explaining the banjo fitting and yes i do know what they are and have used them. Just haven't come accross the term Banjo fitting untill now.
Secondly thankyou for your concern about my competentcy. I have used and terminated swa several times before but not upto 25mm in the circumstances of this job. So please do not be alarmed.
Also experience only comes with doing the job in the first place and rather than plough straight in with my limited experience and knowledge i believe i am do right by this forum to ensure i do the job safely and correctly the first time.
I agree that experience comes with doing a job, but normally the first time is under supervision.
As I said, I didn't mean to insult you, I was just concerned that you were taking on something which you weren't sure about. Glad you know what to do though.
This forum is indeed an excellent resource for new and experienced electricians alike.
Thanks Guitarist. No offence taken.
