Can anyone help, I have looked at a central heating pump for my brother in law (who is a plumber!? it is an HRM oil fired boiler, the problem is that the circulation pump is permanently on, there is underfloor heating with the system, the wiring is shocking and I will probably have to re wire everything but just looking at a quick fix prior to pulling it all out and starting again.
I tested everything out a few weeks back and changed the head on one of the two port valves which appeared to solve the problem, I then left and then it has started running permanently again?
Any ideas as I am a bit lost, is it likely to be some kind of pump over run issue?
