T
tom262
PHP:
if someone could tell me how to upload photos, I will show you.
is this ok?! Apparently it was installed by a previous owner, I've disconnected it as they don't use it anyway but seems abit strange.
Discuss Confused....bathroom socket in the UK Electrical Forum area at ElectriciansForums.net
Forget disconnection times, you need to answer Rockingit's post #9 about why you have come to the conclusion that it is fine with regards to the regs.
How far is this socket from the bath or shower?
No it's not normally, but it's a lot more helpful than some people on here!!That slideshow far from explains all of section 701. Is this your usual technical reference material ?
its in zone 3.
Because it 'electrical separation' there's no earth return path, but how would you know weather this satisfies the disconnection times, I know it dose on the supply side of the transformer but what about the secondary side..?? I've taken all my readings, zs, rcd ect from the supply side but as there's no earth by tester 'fluke' won't take it from the secondary side.
its in zone 3.
Ok, as Andy78 has rightly said, forget disconnection times for now. However, this question reveals a fundamental lack of understanding of what actually constitutes a protective measure, yet you're carrying out PIRs? Take note of the two phrases I have highlighted in bold for you and have a think as to why they should not be in the same sentence.
Where's zone 3?
seems he is being naughty and testing installs to old regs.Ok, as Andy78 has rightly said, forget disconnection times for now. However, this question reveals a fundamental lack of understanding of what actually constitutes a protective measure, yet you're carrying out PIRs? Take note of the two phrases I have highlighted in bold for you and have a think as to why they should not be in the same sentence.
Where's zone 3?
apart from no earth there is no problem with an outdoor socket but there is a problem with the type of appliances and things e.g. hair driyers etc that will get used in there.
in my opinion i would note it should be removed, (you cant just disconnect things without the clients permission)
the regs allow shaver sockets etc at 110v and 240v not appliances.Apart from no earth??? Read the OP again, it's supplied by an isolating transformer and so is using electrical separation as it's method of protection.
What danger do you forsee in using such appliances?
the regs allow shaver sockets etc at 110v not 230v appliances.
it would be a depature from the regs and would need a risk assement carrying out or could land you in hot water in the future if anyone gets a shock
im sure it states sockets need to be 3m away if i remember right.All the isolated shaver socket outlets i've ever seen have been dual voltage!!!!
Reply to Confused....bathroom socket in the UK Electrical Forum area at ElectriciansForums.net
