Connecting 6.0mm T&E | Page 2 | on ElectriciansForums
Discuss Connecting 6.0mm T&E in the UK Electrical Forum area at ElectriciansForums.net
B
besenzig
Running a 20A 6.0mm T&E radial to utility room to supply two single 13A sockets to feed Washing Machine and Tumble Dryer.
The T&E will be terminated in a PVC adaptable box, just wondering how to make the connection to the sockets as terminals
will not take 6.0mm.
Can I use connector strip using 4.0mm or 2.5mm to feed the sockets, was hoping to use Wago but they too will not take 6.0mm.
Is there connector out there that will do the job.
As already said you can get a twin terminal socket for each conductor. If not go for the MK single termination socket. I've got 2 lots of 6mm in before without giving them a hair cut lol. Below is the MK tech spec for a singe termination socket.....
Terminal capacity:
Live, neutral & earth
3 x 2.5mm2
3 x 4mm2
2 x 6mm2 (stranded)
2x 6.0mm conductors will go into an MK socket no problem,but as previously stated they need to be cut square and stripped carefully. Insert into terminal as stripped,dont twist the cores up.
Also dont fit the standard lazy a-rse 25mm flush back box,35mm minimum....45 even better.
It is difficult to stick 2 6mm2 cables into a socket, however the whole thing is wrong. Assuming the 6mm2 is already in place and therefore the OP intends to use it the best method would be a double socket rather than 2 singles, job done, move on LOL
Reply to Connecting 6.0mm T&E in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
