Consumer unit to be moved away from service head | Page 2 | on ElectriciansForums
Discuss Consumer unit to be moved away from service head in the UK Electrical Forum area at ElectriciansForums.net
Chris
Merseyside
Hi everyone.
I have been asked to relocate a consumer unit from a cupboard outside a house into the inside of the property. The main fuse and meter will be remaining outside however the run is about 6/7 metres long, i believe it states in BS7671 that the meter tails cannot exceed 3m in length.
would this require me to put a separate fused connection unit within the 3m of isolater and then run a 25mm SWA + 16mm earthing conductor from the fused connection unit, to the 6/7m away consumer unit location? If not who knows a better way?
thanks, chris.
Tns, but the consumer unit has been moved by someone before we bought the place as the original tails go into the rcd I mentioned earlier then leave the rcd in armoured and go to the unit under the stairs,
Then I cannot see why that RCD has been installed.
Thanks Essex,have been intending to look into this for a while this thread has just given me a kick up the arse,I believe it’s a 100a 100ma rcd main switch,not completely sure its time delayed I’ll have a look later
OP are you berrying the sub-distribution cable in the render as others are assuming that you are or are you cleating direct to render? What is your plan to run this cable?
No i am not burying in render it is my fault for the assumptions as i wasnt very clear, the wall is due to be rendered over and it will be cleated and ran along the wall, then drilled through into property.
Reply to Consumer unit to be moved away from service head in the UK Electrical Forum area at ElectriciansForums.net
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
