***Cont../ Useful Information for Electricians & Apprentices***
A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
RingFinal Circuits . ( Point of Utilisation ) 2005/6
Inthis system the Line . Neutral . & Circuit Protective conductors areconnected to their respective terminalsat the consumer unit , Loop into eachSocket-outlet in turn & then returned to their respective terminals in theConsumer Units . Thus :-
Forminga Ring . Each Socket-outlet has two-outlet has two connections back to the MainSupply .
Considerationmust be given to the loading of the Ring Final Circuit .
SingleSocket - 1 point .
DoubleSocket - 1 point .
LightFitting with 1 Switch - 1 point .
LightFitting with two – 2 way switches & Intermediateswitch = 1 point .
Cooker. Isolator Switch with a combined Socket is - 2 points .
Asthe FirstAmendment No 1 2011 . rightly says
Appendix 15 ( Informative ) p/425
The load current in any part of the circuit should be unlikely toexceed for long periods the current-carrying capacity of the cable (Regulation 433.1.103 refers )
This can generally be achieved .
i) Locating Socket-outletsto provide reasonably sharing of the Load around the Ring .
iv) Taking account of thetotal floor area being served . ( Historically . a limit of 100m[SUP]2 [/SUP] hasbeen adopted )
On Site Guide .
Which is an “ Abbreviated “ version of BS-7671 :yes:
Diversity - Table 1B . R/B O.S.G. p/97 second column
Justa reminder . Example .
Cookers . 100% - of 4000W / 230V = 17.39A
Cookers . 80% - of 3000W / 230V = 10.43A
Useful Junk .
Example . The Screw Rule .
Thedirection of the magnetic field is traditionally using the “ Screw Rule “ :49:
Rotationof Screw = Rotation of magnetic field . “ Clockwise
Directionof Screw = Direction of Current . →
Inthe Screw Rule we think of a normal (Right-hand threaded Screw )
Themovement of the Tip represents the direction of the Current through a straightconductor & the direction of rotation of the Screw represents thecorresponding direction of rotation of the magnetic field .
Definition:
Statutorylaws & regulations are written in a legal framework .
Definition:
Non-statutoryregulations & codes of practice interpret the Statutory regulations telling us how we can comply with the law .
BS-7671:2011 . incorporating No 1
114 . Relations with Statutory Regulations .
114.1. The Regulations areNon- Statutory .
ElectricCurrent .
The drift ofElectrons “ within a conductor is known as an “ Electric Current “ measured in amperes & given the symbol ( I )
Voltagedrop :
Amountof voltage lost due to a résistance ,
Guidance on Initial Testingof Installation(s)
Safety & Equipment . O.S.G. 2011
610.1. it is the Test operative’sduty to ensure their OWN safety . &the safety of others . whilst 612.1. working through Testprocedures . When using Test instruments . this is best achieved by precautionssuch as :-
i Knowledge & experience of the correctapplication & use of the test instrumentation . leads . probes &accessories ( is of the greatestimportance )
612.1. ii checking that the testinstrumentation is made in accordance with the appropriate safety standardssuch as BS-EN 61243-3 foe two pole voltage detectors & BS-EN61010 or BS-EN 6 for instruments.
Iii checking before eachuse that all leads . probes . accessories ( including all devices such as crocodile clips used to attach toconductors ) & instruments includingthe PROVING UNIT are clean . undamaged & functioning; also checking that isolation can besafely effected & that any locks or othermeans necessary for securing the isolation are available & functional .
GN-38 . iv observing the safety measures &procedures set out in ( HSE ) GuidanceNote GS-38 for all instruments . leads . probes & accessories . some testinstrument manufacturers advise that their instruments be used in conjunction withFUSED TEST LEADS & PROBES when the instruments has in-built electrical protectionbut it should be NOTED that such Electrical Protection does NOT extend to the ( PROBES & LEADS )
Making you Aware
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/35 - p/47
537.5. Functional Switching
537.5.1.1. A switch must beinstalled in each part of a circuit which may require to be controlledindependently of other pars of the installation .
530.3.2. Switches must not be installed in the neutralconductor alone .
537.5.1.3. Allcurrent-using equipment requiring control shall be controlled by a switch .
537.5.2.3. Off-loadisolators . fuses & links must not be used for functional switching .
NOTE : Table 53.4. of BS-7671:2008 – ( 2011 ) permits the use of CIRCUIT-BREAKERS for functional switching purposes but . in each case . The manufacturershould be consulted to establish suitability .
Making you Aware
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/33 - p/45
537.2. Isolation .
132.15.1. - 5.1.1. Requirement ◄◄
537.1.4. (i) A main linked switch or circuit-breakershould be provided as a MEANS of isolation & of interrupting theSUPPLY on LOAD .
For SINGLE-PHASE household &similar supplies that may be operated by UNSKILLED PERSONS . a DOUBLE-POLE DEVICE must be used for ( TT & TN- systems ) ◄◄
For a THREE-PHASE supply to an installation forming part of a TT system . an isolator MUST interrupt the LINE & NEUTRAL CONDUCTORS .
In a TN-S or TN-C-S system ONLY the LINE CONDUCTORS need be INTERRUPTED . ◄◄
Making you Aware ( Extracts ) refer to Copper Conductors & are Relatedto 25mm[SUP]2[/SUP] SupplyTails from the Meter .
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/32 - p/44
Typical Earthing Arrangements for Various Types of Earthing System.
Making you Aware
542.4.2. The earthing ( BAR ) is sometimes used as the ( MAINEARTHING TERMINAL ) .
However . means MUST beprovided in an Accessible Position forDisconnecting the Earthing Conductor to facilitate measurements’ of ExternalEarth Fault Loop Impedance . ( Ze )
NOTE : for TN-S & TN-C-S installations .
ADVICE . about the availability of an Earthing Facility & the Precise arrangement for CONNECTIONshould be OBTAINED from the Distributor or Supplier .
Making you Aware . Extracts.
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/31 - p/43
Earth Electrodes .
NOTE : Regulation 542.2.6.PERMITS the USE of privately owned WATERsupply PIPEWORK for Use as an EarthElectrode where precautions are taken againstits REMOVAL & it has been consideredfor SUCH USE .
This relaxation will NOT APPLY to an INSTALLATION within a ( DWELLING ) ◄◄ 2392-10 :gettree:
Making you Aware . Reminder .
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/30 - p/42
415.2. Supplementary EquipotenalBonding is REQUIRED in some of theLOCATIONS & INSTALLATIONS ( Falling within the SCOPE of Part 7 of BS-7671 )
If the installation MEETS the REQUIREMENTS of BS-7671:2008 – ( 2011 ) FOR Earthing & Bonding . There is NO SPECIFIC REQUIREMENT for Supplementary Equipotenal Bonding OF.
□ Kitchen pipes . sinks or draining boards .
□ Metallic boiler pipework .
□ Metallic furniture in KITCHENS .
□ Metallic pipes to Wash-hands basins & WCs .
□ Locations containing a BATH or SHOWER . ►► PROVIDING the CONDITIONS ofRegulation 701.415.2 ARE MET
NOTE : Metallic waste pipesdeemed to be ( Extraneous-conductive-parts ) must be connected by main protectivebonding conductors to the main Earthing Terminal .
See also 4.3.
Change .
4.2. ) Copper Earthing conductors cross-sectional area ( C.S.A. ) for TT supplies for Earth Fault Loop Impedance notless than ( 1 ohm ) p/29
Notes :
1) protected againstcorrosion by a Sheath .
2) for impedances less than (1 ohm ) determine as per Regulation 543.1.2.
3) The main protective bonding conductors shall have across-sectional area of not less than half that required for the earthingconductors & not less than ( 6mm[SUP]2[/SUP]) Regulation 544.1.1.
4.4. (ii ) Copper Earthing conductors cross-sectional area ( C.S.A. ) for TT supplies
Notes :
2) The main protective bonding conductors shall have across-sectional area of not less than half that required for the earthingconductors & not less than ( 6mm[SUP]2[/SUP]) Regulation 544.1.1.
4.4. (ii ) Bonding connections to incoming metalservices should be made as NEAR as practicable to the point of entry of theservices into the premises . BUT on the Consumer’s Side of any Insulating Section . 544.1.2.
□ Reminder . (- Main Protective Bonding of Plastic Services. p/41 .
There is ( NO REQUIREMENT ) to Main Bond an incoming service where theincoming service pipe is ( PLASTIC )
Example (- Where YELLOW is USED for NATURAL GAS & BLUE for Potable Water .
Making you Aware . Reminder . OFF THE WORDING .
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/7
110.1. The scope generallyfollows that of BS-7671 . The guide includes material NOT included in BS-7671. provides background to the intentions ofBS-7671. & gives other sources of ( INFORMATION ) HOWEVER . IT DOES NOT ensure compliance with BS-7671 . it is a SIMPLE GUIDE to the REQUIREMENTS of BS-7671. to satisfy themselves of COMPLIANCE .
It is expected that persons carrying out WORK in ACCORDANCE withthis GUIDE will be COMPETENT to do so .
HSR25 . EWR . ◄◄ Electrical installations . in the United Kingdomwhich comply with the IET Wiring Regulations . BS-7671 MUST COMPLY with all relevant statutory regulations . such as the Electricity atWork Regulations 1989 - ( Regulation 16 ) The Building Regulations & . where relevant. the Electricity Safety . Quality & Continuity Regulations ( 2002) & Amendment ( 2006)
That’s why the Assessor will ask for the BS-7671:2008 First Amendment . NOT the O.S.G.
Building Regulations . p12.
The Building Regulations ofEngland & Wales .
p/13 - Note : Guidance isavailable for each part of the Building Regulations in the form of Approved Documents which can be freelydownloaded from the Department for Communities & Local Government ( DCLG ) website : www.planningportal.gov.uk
O.S.G. - First Amendment . BS-7671:2008 – ( 2011 ) p/12
This guide also contains information which may be required ingeneral Installation Work . for Example . conduit & trunking capacities .bending ( Radii ) of cables . etc .
The guide introduces the use of standard circuits . which arediscussed in Section 7 . however .because of simplification . This Guide may NOT give the most ECONOMICAIL RESULTS .
This Guide is NOT a REPLACEMENT for BS-7671. which should ALWAYSbe CONSULTED .
Defined terms according to Part 2 of BS-7671 are Used .
In compliance with the definitions of BS-7671 . Throughout thisGUIDE the TERM . Line conductor is Usedinstead of Phase conductor & Live part is Used to refer to a conductor orconductive part intended to be energised in normal Use . including a Neutralconductor .
The terminals of electrical equipment are identified by theLetters . L . N . & E . ( or PE )
NOTE : for Clarification.
► The distributor of electricityis deemed to be the organisation owning the electrical supply equipment . &
► The supplier of electricity is the organisation from whom electricityis purchased .
amberleaf,
Dan,
