View the thread, titled "***Cont../ Useful Information for Electricians & Apprentices***" which is posted in Australia on Electricians Forums.
A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
Appendix 15 ( Informative )
Ring final circuit arrangements .Regulation 433.1..103 .
2392-10 :
The load Current in any part of the circuit should be unlikelyto exceed for long periods the Current –carrying capacity of the cable ( Regulation 433.1.103 refers )
Thiscan generally be achieved . p/425 .
i) Locating socket-outletsto provide reasonable sharing of the Load around the Ring . :svengo:
iv) Taking account of thetotal floor area being served . ( Historically . a limit of 100m[SUP]2[/SUP] has been adopted ) :svengo:
Does the ( R1 + R2 ) Test confirm the correct polarity of a radialcircuit .
NO )- not on it’s Own Whilst the test can provide an Indication ofpolarity . it needs to be combined with Inspection & further Testing asrequired by part 6 - BS-7671:2008 .
January1[SUP]st[/SUP] 2005 Legislation came into effect which broughtElectrical Work in Dwellings under the BuildingRegulations . ( & made it aControlled Service )
ThisAmendment to the Building Regulations .Known as ( Part P ) imposes “ SAFETY “ REQUIREMENTS
ClassifiesElectrical Installation Work – into two basic Categories , ( Notifiable ) & ( Non-notifiable )
BS-1363: Plug there isn’t ( YET ) a regulation to prevent you from plugging itin .
Eachtype of Fuse has a ( Time – current characteristic) which shows the time required to Meltthe Fuse for any given level of Overload Current .
AFuse is a very basic protection device which is destroyed ( i.e. it Blows )
Just a reminder .
Definitions – p/34 .
Résistance Area - ( R[SUP]a[/SUP] ) . ( for an Earth Electrode Only ) The surface area of ground ( around an Earth Electrode) on which a significant voltage gradient may Exit . :rant:
Justmaking you Aware . -&-s . Common Q/As :santa5:
Stationary Equipment . p/35- p/30 .
Electrical Equipment which is either Fixed or whichhas a Mass Exceeding ( 18kg ) & is Not provided with a carrying handle .
Definitions’ )- p/23
Accessory “ Means . a device . other than current-usingequipment . associated with such equipment or with the wiring of an installation.
Appliances “ Means . an item of current using equipment other thana luminaire or an independent motor .
Supplier– see Distributor
Distributor p23 : Aperson who distributes electricity to consumer using electrical lines &equipment that he/she owns or operates .
Origin of an Installation p31 : Theposition at which Electrical Energy is delivered to an Electrical Installation
Wordingfrom a 2392-10 point of View . ( At the Origin ) ▲ :svengo:
Surge Current P/35 : A transientwave appearing as an Overcurrent caused by a ( Lighting Electromagnetic Impulse )
Surge Protective Device (SPD ) P/35
A device that is intended to limit transient overvoltage’s &divert surge Currents .
p/141.Basics )- 534.2.1. Use of ( SPDs )
where required by Section 443 or otherwise specified . SPD shallbe installed .
i) Near the origin of aninstallation . or
ii) In the main distribution assembly nearest the origin of aninstallation .
534.2.3.6. p/145 Co-ordination of SPDs
SPDs shall be selected & erected such as to ensurecoordination in operation .
536.2. Selectivity between overcurrentprotective devices .
Where Selectivity between overcurrent protective devices isnecessary to prevent danger & where required for proper functioning of theinstallation . the manufacture’s instructions shall be taken into account .
536.3 p/148 . Selectivity betweenRCDs .
Where Selectivity between RCDs . is necessary to prevent danger& where required for proper functioning of the installation . the manufacture’sinstructions shall be taken into account .
Abrasion . damage to wiring systems due to : p/437 :christmastree1:
522.6.1.
Impact ( AG ) p/124 .
Wiring systems shall be selected & erected so as to minimizethe damage arising from mechanical stress . e.g. by impact . abrasion .penetration . tension or compression during installation . use or maintenance .
717.52.2. – (ii) p/248. The wiring systemshall be installed using one or more of the following :
ii) Sheathed flexible cablewith thermoplastic or thermosetting insulated to BS-6004. BS-7211 or BS-7919 .if precautionary measures are taken such that no mechanical damage is likely tooccur due to any sharp-edged parts or abrasion .
721.522.7.1. Vibration ( AH) p/255
As the wiring will be subjected to vibration . all wiring shall beprotected against mechanical damage either by location or by enhanced mechanicalprotection . Wiring passing through metalwork shall be protected by means of suitable bushes or grommets . securelyfixed in position . Precautions shall be taken to avoid mechanical damage due to sharp edges or abrasive parts .
Whenmust the Test be Carried Out . :60:
InitialVerification : consists of Visual Inspection& Testing . of ElectricalInstallation to determine ( as reasonably practicable ) have been met . includingrequirements for the Reporting of the Test Results.
610 : Initial Verification.
610.1. p/189 .
Every installation shall . during erection & on completion beforeput into service . be Inspected & Tested to verify . so far as is “ reasonably practicable “
That the requirements of the regulations have been Met .
610.3 :
The Verification shall include comparison of the results with relevantcriteria to confirm that the requirements of the regulations have been Met .
2392-10 (- as Regulation 610.6. rightly reminds us . On Completion of the Verification .according to Regulation(s) 610.1. to 610.5 a Certificate shallbe prepared
611 : Inspection .
611.1. Inspection shallprecede Testing & shall normally be done with that part of the Installationunder Inspection disconnected from the Supply .
612. Testing
612.1. The Tests ofRegulations 612.2. to 13 . Where relevant. shall be carried out & the results compared with relevant criteria .
612.13. 2392-10 . from your point of View
Functional Testing . is the Last Test . ( &Operational Tests )
AsRegulation rightly says . 612.14.
Note : Verification of voltage drop is NOT normally required duringInitial Verification
632 : Initial Verification
632.4. Defects or Omissions revealed during Inspection & Testing of the Installation workcovered by the Certificate shall be made good before the Certificate is Issued.
InsulationRésistance :
WhereSurge Protective Devices ( SPD ) arelikely to Influence the Test or be Damaged . such equipment shall bedisconnected before carrying out the Insulation Résistance Test . ( These will be creeping in after next year . -&-s Q/As )
Whereit is NOT reasonably practicable to disconnect suchequipment . ▲
2392-10. NOTE 2 (- Insulation Résistance values are usually much “ HIGHER “ than those of Table 61 . p/191. p/158 . 500V / 1.0MΩ . Etc.
What is Verification “Meaning “ :gettree:
Definitions : p/36 Verification .
All measures by means of which “ COMPLIANCE “ of the electrical installation with the relevantrequirements of BS-7671 are CHECKED .
Verification of theProtection by ( MCB ) in a ( TN – System ) ◄◄
According to BS-7671:2008 .No 1 : 2011
Maximum value of ( Zs ) .Example - 1.44Ω / MCB 16A . Characteristic C )
As an Inspector “ Your Instrument reads ( 1.14Ω ) or 202A on Fault Current Range . it means that the condition ( Zs x Ia ≤ Uo )
The ( Zs ) of 1.14Ω is Less than ( 1.44Ω ) or the Fault Currentof 202A is more than ( Ia ) of 160A .
In case of Fault between Line & Earth . The wallSocket Tested in this ( Example ) Protected because the MCB will trip withinthe disconnection time required.
Table 41.3. – p/56
Type C – 16A – 1.44Ω
According to BS-7671:2008 . No 1 : 2011
Maximum Earth Fault Loop Impedance ( Zs ) for circuit breakers with Uo of 230V . for instantaneous operation giving “ COMPLIANCE “ withthe ( 0.4s ) disconnection time of Regulation 411.3.2.2. .
NOTE : 411.3.2.2.
The Maximum disconnection time Stated in Table 41.1. SHALL be applied to FINAL CIRCUITS NOT exceeding ( 32A ) 0.4s / TN- ◄◄
Electrical Installation Condition Report . p/396 :carolers:
The inspection & testing detailed in this report &accompanying schedules have been carried out in accordance with BS-7671:2008( IET Wiring Regulations ) as amended to ….
It should be NOTED that cables concealedwithin trunking & conduits . under floors . in roof spaces . &generally within the fabric of the building or underground . have NOT been Inspected unless specifically agreed between the Client& Inspector prior to the Inspection .
BS-5266 : EmergencyLighting .
110.1.3. (ii) . p/14
The regulations are intended to be applied to electrical installationsgenerally but . in certain cases , they may need to be supplemented by therequirements or recommendations of other British or Harmonized Standards or bythe requirements of the person ordering the work . ETC .
(ii) Emergency Lighting – BS 5266
528.1 . Note 2 . P/133 Proximity toelectrical services .
Except where one of the following methods is adopted . neither a voltage Band 1 nor a voltage Band 11 circuitshall be contained in the same wiring system as a circuit of nominal voltageexceeding that of low voltage . & a band 1 circuit shall not be contained inthe same wiring system as a Band 11 circuit .
Note 2 . Requirements forseparation & segregation in relation to safety services are given in BS-5266 & BS-5839.
560.8.1. Note 2 . P/186
One or more of the following wiring systems shall be utilised forsafety services required to operated in fire conditions .
Note 2 : BS-5266 . BS-5839 & BS8519 specifiescables to BS-EN 60702-1 . BS7629-1 & BS-7846 asbeing suitable when appropriately selected for this application .
(ii) Emergency Lighting –BS-5266.
560.9. p/187 .
Emergency lighting system shall comply with the relevant parts ofBS 5266 series .
710.560.9.1. – (i) p/236 . Safety Lighting .
In the event of main power failure . the changeover period to thesafety services source shall not exceed 15s . The necessary minimum illuminance shall be provided for the following .
(i) Emergency lighting& Exit Sign to BS-5266 .
BS-5266 : EmergencyLighting . Code of practice for the EmergencyLighting of premises . 560.8.1. note 1 – (i) p/186
Note 1 : The codes of practice in the UK for emergency lighting . firealarms & life safety & fire fighting applications are :
(i) BS 5266 Part 1 : Emergency lighting – Code of practice for theemergency lighting of premises .
E.A.W.R.1989 . Compliance - Electricity at Work Regulation . :svengo:
Regulation ( 16 ) Person to be Competent.
Status/ Absolute .
Noperson shall be engaged in any work activity where technical knowledge or experience isnecessary to prevent danger . or where appropriate . injury . unless he possessessuch knowledge or experience . or isunder such degree of supervision as may be appropriate having regard to thenature of the work .
LegalRequirements .
Toachieve compliance with the legal requirements of the Electricity at Work Regulations1989 requires proof that an electrical system is safe . which involves amongstother things . proper Inspection & Testing of an system by competent person(s)& the creation & maintenance of records .
First Amendment . p/25
Competent Person .
A person who possesses sufficient technical knowledge . relevant practicalskills . & experience for the natureof the electrical work undertaken & is able at all times to prevent danger& . where appropriate . injury to him /herself & others .
Failureto comply with the Building Regulations is a criminal offence & localauthorities have the power to require the removal or alteration of work thatdoes not comply with the requirements .
What is the Requirements of Part P .
It is a Legal requirement for all work on Fixed ElectricalInstallations in dwellings & associated buildings to comply with RelevantStandards .
TheRelevant UK Standard is :
BS-7671:2008 . Requirements for electrical installations ( IET Wiring Regulations 17[SUP]th[/SUP] Edition. First Amendment . ) :rant:
BS-7671:2008 . Covers requirements for Design . Installation . Inspection . Testing .Verification & Certification .
UsefulJunk .
Part P : Applies to parts of Electrical Installationsthat operates at voltages NOT exceeding 1000V a.c.
Certification.
BS-7671:2008. requires that a person installingelectrical work or altering an existing installation must test the installation& provide certification to the owner.
FundamentalPrinciples . are intended to provide for ( Safety ofPersons ) Livestock & the Protection of Property against Dangers &Damage which may arise .Etc
Touch Voltage
Reminder. The Objectof BS-7671:2008. First Amendment No 1 2011 .
Chapter 41 . Protection against Electric Shock .
The PROVISION of requirements CONCERNING protection AGAINST Electric Shock .
The Touch Voltage concept is concerned with the latter form of ( Electric Shock ) it is used to determine the ( Magnitude ) of voltage to which the Person at ( RISK ) would be subjected in the ( EVENT ) of an EARTH Fault Occurring in an Installation .
Part P : Applies to parts of ElectricalInstallations that operates at voltages NOT exceeding 1000V alternatingcurrent .
Justa Reminder .
Whatare Electrical Installations defined as . Plain English .
Anyfixed Electrical Cables or fixed electrical equipment located on the consumer’sside of the electricity supply meter . it also includes Low voltage & Extra-low voltageinstallations .
What are Electrical Installations defined as . 2011
Voltage . nominal . p/36 – p/31.
Voltage by which an installation ( or part of an installation ) isdesigned . the following ranges of nominal voltage ( r/ms values for A.C. ) are defined .
“ Extra-low voltage “ meansvoltage not exceeding .
i) in relation toalternating current . ( 50 ) volts between conductors & earth . OR
ii) in relation to directcurrent . ( 120 ) volts between conductors .
“ Low voltage “ meansvoltage not exceeding .
i) in relation toalternating current . ( 1000 )volts between conductors or ( 600 )volts between conductors & earth . OR
ii) in relation to directcurrent . ( 1500 ) volts between conductors . or ( 900 ) volts between conductors & earth .
PartP . Electrical Safety . Design &Installation . p/16
P1 . Reasonable provision shallbe made in the design & installation of electrical installation(s) in orderto protect persons operating . maintaining or altering the installations fromfire or injury .
Limits on Application . :svengo:
Therequirements of this part apply ONLY toelectrical installation(s) that are intended to operate at . Low-voltage or Extra-low voltage & are : ◄
a) in or attached to a dwelling.
Reply to the thread, titled "***Cont../ Useful Information for Electricians & Apprentices***" which is posted in Australia on Electricians Forums.
