***Cont../ Useful Information for Electricians & Apprentices***
A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
Methodsof Inspection & Testing are described in Guidance Note : 3
Wherea . 3-core cable . with cores coloured . Brown . Black . Gary . is used as a switch wire for two – wayor intermediate control . the terminations of the conductors shall beidentified using . [ Brown tape on the . Black & Gray cores ]
2392-10: Inspectors . [ Assessor ]
Theneed to comply with the relevant parts of the . Electricity at Work Regulations1989 .
Whenreplacing a Or working on a Consumer Unit .
Regulation12 : Means for cutting off the supply& for isolation .
Regulation13 : Precautions for work on equipment made [ Dead]
Regulation14 : Working on Or near Live conductors .
2392-10: Inspectors
Replacinga [CU] in an existing installation is anAddition Or Alteration to that installation .
Therefore: be designed . erected & Verified in accordance with the requirements of the currentedition BS-7671:2011 .
Inspectors
Mustnot impair the safety of the installation .Regulations 110.1 ( x )
(x ) External lighting & similar installations .
610.4.
Foran Addition or Alteration to an existing installation .it shall be [ Verified ] that the Addition or Alteration complies with the Regulations . & does not impair thesafety of the existing installation .
110.1.1. : Note : “ Premises “ covers the land & allfacilities including buildings belonging to it .
110.1.2. : (vi) Additions& Alterations to the installations & also [ Parts ] of the existinginstallation affected by an Additions& Alterations . 610.4.
Design& Installation .
Workshould comply with BS-7671:2011
Part M . of the building regulations must be complied with .
Inspection& Testing before taking into service .
BS-7671:2011. does not recognize a kitchen as a special location . PartP does .
TheDomestic Electrical Installation Condition Report .
Isused to report on the safety condition of an existing installation in adomestic situation .
2392-10: ( EIC ) is a declaration of Electrical Safety .
(EIC ) is to be issued to confirm that the electrical installation work to whichit relates has been designed .constructed . inspection & tested in accordance with BS-7671:2011 .
(EIC ) is to beused only for the Initial Certification of a new installation . Or for an Addition orAlteration to an Existing Installation where new circuits have been [ Introduced ] 2392-10 :
ThisCertificate is onlyvalid if accompanied by theSchedule of Inspections & the Scheduleof Test results .
(EICR ) Report is for use when carrying out routine periodic inspection & testingof an existing installation . it is notfor use when Alterations or Additions are made .
DomesticPeriodic Inspection Report .
isfor use when carrying out routine periodic inspection & testing of an existinginstallation . it is not for use when Alterations or Additions are made .
a Schedule of Inspections & Schedule of Testresults should accompany the Domestic Periodic Inspection Report .
(MEIWC ) When an Addition to an electrical installation does not Extend to theinstallation of a new circuit .
(PAT Testing - CoP )
Althoughthere is No requirement in the ( EAWR 1989 ) to keep records of equipment & ofinspections & tests . ( HSE 1974 ) Memorandum of Guidance on theseregulations advises that records of maintenance including tests should be keptthroughout the working life of equipment .
Inspection& Testing .
& without such records dutyholders cannot be certain that theInspection & Testing have actually been carried out .
Oneof the Fundamental Principles . that 2391-10 . lost marks on was . ◄◄◄
Identifythe simplest of tests . applied in the Regulations & GN-3 .
Theyare only two tests that can apply . PeriodicInspecting & Testing & Initial Verification .
2392-10: Initial Verification . – New Installation - ( EIC ) Exams
2391-10. Periodic Inspection & Testing . ( EICR ) ExistingInstallations .
ConditionReport Inspection Schedule for (Domestic & Similar Premises with up to 100ASupply )
PeriodicInspection & Testing . Exams
p/400: Regulation 2011 . Note : Thisform is suitable for many types of smaller installation NOT exclusively domestic . 2392-10 ◄◄◄ Wording
2011: Earth electrode for RCDs . ( TT with RCDs ) 2392-10
GN-3: Electrode under test is being used inconjunction with a residual current device the following method of test may be appliedas an alternative to the Earth Electrode résistance test .
Inthese circumstances . Where the electrical resistances to earth are relativelyhigh & precision is NOT required . an Earth Fault LoopImpedance Tester may be Used .
Q) : The test required by regulation to ascertainthat the CPC is correctly connected is called . 612.2.1. Continuityof Protective Conductors . 2392-10
2392-10:
Both Online & Practical . must be passedto receive City & Guilds Certification .
Practical& Theory assessments . relating tothe Inspection & Testing – of NewInstallation .
A Must??
Safeworking .
- Isolationpractices .
- Use of test equipment .
- Inspection& Testing documentation .
if not sure pair up . Testingon the Boards . ►► Make Sure that youfill in the Certificates fully . :banghead: :13:
CalibrationCertificates . last for a Year .
Testinstruments must . therefore . be tested & [ Recalibrated] each year .
Testresults are to be [ Valid ] the instrument must also carry a CalibrationCertificate . This will go onto your Certificates / Model number .
2392-10: -&-s .make no discrimination . on matters . Certification of ElectricalInstallations . being!! Testing & Verification .
Howto [ Code ] electrical Inspection items . completeCertificates . ( EICR / Codes ) p/397 . Exams – C1 : C2 : C3 :
Q) The legal responsibilities of an Inspector .
Q) The general requirements of BS-7671: relating to Initial Verification .
Q) The inspection process & testing requirementsfor New Installation(s)
-&-s. Which [ Certificate ] to use & when & how to usethem . you will get this on your 2392-10 Exam & Practical Assessments . “ On the Boards “
Completionof ( EIC ) certificate details . this is the Important certificate details . Exams & -&-s .
Electrical Installation Certificate - ( EIC)
Regulation631.1. requires that .upon completion of the [ Verification] of a New Installation. 2392-10 . Domestic Installation .
Domestic electrical work that falls under Part P .Building Regulations .
Or changes to an Existing Installation. GN-3 . shall be provided - Section 632.
632.2 - Uponcompletion of the periodic inspection & testing of an [ Existing Installation ] - ( EICR )
Identification& resolution of common problem .
-&-s. Knowledge necessary to carry outInspection & Testing on New Installations . [ Initial Verification]
p/36 . Verification : All measuresby means of which compliance of the electrical installation with the relevantrequirements of BS-7671 are checked .
Comprising Inspection . Testing & Certification .
Certification . [ Certification & Reporting ] p/195 / 196 . Requirementsfor electrical installation(s)
(EIC ) - ( EICR ) - ( MEIWC )
PeriodicTesting . ??
Anyimmediately dangerous condition should preferably be rectified . in not , thedefect should be reported without delay to the employer or responsible employee .
Regulation3 of the EAWR .
Regulation3 . places Duties On .
Employers. employees & the self-employed . tocomply with the Regulations as far as matters are under their control .
Employees. to co-operate with their employer .
Theregulations quantify these responsibilities . by putting them under a legalduty to work in accordance with the requirements of the Regulations .
Definitions:
ElectricalEquipment .
Includesanything used . intended to be used or installed for use . to generate .provide . transmit . transform . rectify . covert . conduct , distribute .control . store . measure or use electrical energy .
System:
Coversall & any electrical equipment which is . or may be . connected to anelectrical energy source . & includes that source .
• Whichof the following IP Codes signifies protection against total immersion inwater: this Q) comes up a lot .
( An “ X “ isused for one of the digits if there is only one class of protection ) Example . Use IPX4 - which addresses moisture résistance only . 2392-10 .
[ Each ] digit represents an [ Individual level of Protection ]
IP ] Ingress Protection Rating.
X ] which addressesmoisture résistance only
4 ] Protected against splashing water .
2392-10: let’s look at it another way . “ Client’s Need’s “
Imust stress . Emphasising that the “ Client “ as the customer is the main influence of any . [ re-wires ] “ Client “ requirements need tobe satisfied .
Hi Bruce
411. Protective Measure – Automatic Disconnection of Supply. ( ADS )
2392-10. Threecomponents . ◄► FaultProtection .
411.3.1.1. Protective Earthing .
411.3.1.2. Protective Equipotential Bonding .
411.3.2. Automatic disconnection in a Case of a Fault.
“ Second Digit “ [ IP ]
2 ] Protection against dripping water when tiltedup to 15% .
4 ] Protectedagainst splashing water .
5 ] Protected against water jets . .
6 ] Protected against heavy seas .
7 ] Protected against the effects of - [ Immersion]
8 ] Protectedagainst complete - [ Submersion ]
Definitions. for degrees of protection provided by enclosures of electrical equipment as:
i) Protection of person against access to hazardous parts inside the enclosure .
ii)Protection of the equipment inside the enclosure against ingress of solidforeign objects .
iii) Protection of the equipment inside theenclosure against harmful effects due to the ingress of water .
Protection Against Overcurrent .
Regulation. 131.4.
TheElectricity at Work Regulation 1989 =Part 11 . “ States “
That “ Efficient “ means . suitably located . shall be provided for protecting from “ Excess “ of current every part of the system as may benecessary to prevent danger .
Regulation . Reinforces this . 131.4. States that “ Persons & Livestock “ . shall be protected against injury. & property shall be protectedagainst damage .
Due. to excessive temperatures orelectromagnetic stress caused by Overcurrents . likely to arise in Live conductor’s .
2392-10: 131.2.2.. NOTE:
Inconnection with fault protection . the application of the method of protectiveequipotential bonding is one of the important principles for Safety .
ProtectionAgainst fault current :
Regulation. Reinforces this . 131.4. States that “
TheElectricity at Work Regulation 1989 =Part 5 . “ States “
That “ NoElectrical “ equipment shall be put into use where it’sstrength & capability may be exceededin such a way as may give rise to danger .
Regulation 131.5.
Whichrefers to any [ conductor(s) ] being able to carry fault current withoutgiving rise to excessive temperatures . ( inAddition )
Anyitem of electrical equipment intended to carry fault current shall be providedby mechanical protection against electromagnetic stress which could result ininjury or damage to persons . livestockor property . .
Niceone Bruce .
Hospitals’: 2011.
-&-s. Q) The connecting of a Mobile Generator ? . this may be achieved by a [ Plug-in-facility ] BS-EN-60309 - Socket
p/283: BS-EN-60309 : Plugs . sockets-outlets . & couplers forIndustrial purposes . Table - 54.4. [ 551.4.4.note ]
Regulation p/171: - 551.4.4 . NOTE : for suitable connection arrangements see . BS-EN-60309 - Series .
!!!. Do I Need . An External earth leadconnection to the Generator Star . ??
Explain the terms
a. Earthing : p/27
b.
Bonding Conductor. : p/23 . A protective conductor providing Equipotential Bonding .
lets Open it Up .
Solution
a. Earthing: connection of the exposed conductive parts of an installation tothe main earthing terminal of that installation.
b. Equipotential Bonding . Electrical connectionmaintaining various . exposed-conductive-parts &extraneous-conductive-parts at substantially the same potential .
Wording: “ Meanings “
Twotypes of [ Bonding ] normally used are
• Main protective bonding . &
• Supplementary protective bonding . [ where required ]
Main protective bonding – is alwaysrequired .
Reasons: Bonding reduces the voltage theremight have been .
[MET ] A terminal block . where Earthing & Bonding conductor(s) are connected together . Etc
Protective Equipotential Bonding411.3.1.2.
Ineach installation . Main protective bondingconductors . shall connect to the [ MET ] ► Extraneous-conductive-parts including the following .
i)Water installation pipes .
ii)Gas installation pipes . Etc .
Bonding– the correct title is ‘ Equipotential bonding ’. ‘ Electrical connection maintainingvarious exposed-conductive- parts and extraneous-conductive-parts at substantiallythe same potential ’
Ohm’sLaw .
Thecurrent in Amperes ( I ) is equal to theelectromotive force . Or Voltage ( V) divided by the Résistance ( R ) inohms .
Current (I) = Voltage (V) / Résistance ( R ) : I =V/R .
CurrentFlow - System voltage & Loadrésistance determine the flow of current.
ShortCircuit - Accidental connection createsfault . During a Short-circuit . onlythe résistance of the fault path limits current . Current may increase to manytime’s the load current .
Overloadis defined as an Overcurrent that is confined to the normal current path . “Excessive “ connected loads . ( StalledMotor’s ) Can Overload a circuit .
Mostconductors can carry a moderate Overload for a [ Short duration without damage]
Start-upOr Temporary Surge Currents : Motor’s . Transformer’s.
Overcurrents protection must be selected that will carry thesecurrents . MCB .
Short-circuitis any current not confined to the Normal path.
The “ Term “ comesfrom the fact that such current’s. bypass the normalload . Etc . Short / path around the Load . When a current isGreater than . normal current .
[ Short-circuit’s. ] are usually caused by Accidental contact Or wornInsulation . damage occurs . Facts. [ Moreserious than Overloads ]
[ Short-circuit’s. ] include two Or more conductors accidentallytouching . Short-circuit / Fault currents.
Typesof Electrical Fault’s :
Overcurrents– can be divided into two categories . Overloads / Short-circuits .
Anyelectrical current that “ Exceeds “ therating of the circuit is an “Overcurrent “
Or worn Insulation . damage occurs .
ATest that can be take for Granted . youwill get this on your 2392-10 . practical
Theimportance of this test . is that you could have damaged your cable duringInstalling it .
632.4. Defects or omissions revealed duringInspection & Testing of the Installation work . Shall be made good beforethe Certificate is issued .
p/31 : Origin of anInstallation : The position at which electrical energy isdelivered to an electrical installation .
p/24 : Circuit An assembly of electrical equipment supplied from the same Origin &protected against Overcurrent by thesame Protective device(s)
p/25 . Circuit breakers: .
Circuitbreakers : are designed to protectcircuits from Overloads &Short-circuits conditions . When applied within their ratings .
MCB. is connected to an electrical circuit& acts as a bridge between the circuit & the power supply .
MCBs. are designed to protect electrical circuits from being Overloaded .
Calculatea Watt-load for circuit breakers . 10A x 230V = 2300W .
amberleaf,
Dan,
